ok guys, so my car is missfiring and i dont know why...ive upgraded my coil packs to split fires and my spark plugs to iriways which were like $36 a pop and were recommended on the forums and are only like 1k km old ..so whats next? im thinking of just cleaning the coil packs and giving that a go and also i dont have a cover over the coil packs and i heard that lets moisture in? so i might search for one because i have my car booked in for a tune next week :devil: any help would be great. thanks
https://www.sau.com.au/forums/topic/321356-yes-another-missfire-thread/
running 12psi but it spikes 14psi, i got the ngk iriway spark plugs they come already gaped at .8mm.....im guessing maybe its because i bought the split fires second hand...but ive had them for like 6 months and no problem..im hoping its not the coils, and not the spark plugs lol because ive spent heaps on both of them. its not a really bad miss fire, just a few pops
no i havnt had it washed or detailed, only when i have it on high boost it will pop when hitting 5k rpm, on low boost might pop a tiny bit. i heard wrappin ur coil packs in silcone works, wot kind of silcone do i use?
Well that depends on the purpose of the silicone. Are you trying to retard water and keep moisture out? Are you trying to make a seal? If you're trying to keep water out, get a silicone which is safe for plastics(some of them have harmful fumes which can deteriorate plastics).
Did this start all of a sudden? Did you change anything? Is your engine running rich or lean? If its rich its unburnt fuel, if its lean, it could cause popping and it could mean your fuel pump is failing and falling behind when hitting high boost.
sounds like the stock ecu trying to protect your engine from too much boost, it will probably go away with the powerfc fitted.
ok so i was bored at 1am and decided to pull apart my engine bay, i took out the coil packs and cleaned them with silcone spray coz they were WAAAY too dirty all over....pulled out the spark plugs, and i noticed 1 spark plug had alittle hairline fracture on the side of it, but because i didnt have a spare spark plug i just put it all back together n thought id give it a run...and now its not miss firing, could cleaning of the coil packs make it stop miss firing? and should i replace that 1 spark plug?
If it missies again its because its hitting 14psi with 1.1gap and just use the cheap copper ones if gona be running more than 12 psi get yourself a set of bcrpre7s like $3 each and they come gaped at 0.8 and that will not missfire under high boost. But yeah could of been just maybe the sparkplug was to loose or the coil pack wasnt on the spark plug well if its gone now.
This is most likely your problem.
If I remember correctly, stock ECU will have hissy fit when you run more than 10psi boost.
Get PFC tuned, it should solve the problem.
they arnt cheap spark plugs bro, they r ngk iriway7's $36 ea gaped at 0.8mm, i think it was because they were abit loose or coz the coil packs were dirty coz now its working fine :S.
Nah im saying you should use the copper ones there the best at the end of the day. The iriway and all that is just waste of money for no gains.
oh ok, well thanks for that..if it starts miss firing again i might go those then
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
