i purchased these rims for a project i had... now lost my interest in it
MERCEDES BENZ W203 19" AMG (very rare + expensive)
they are in mint/exceptional... not even a touch of a scratch on em...
they are...
2x 19x8.5 (front)
2x 19x9.5 (rear)
rims include 4x center caps+ 4x chrome valves +20x studs
the wheels have never been fitted with a tyre
$1500 neg. (excellent price, chasing quick sale)
p/up preferred from south eastern suburbs, can post if buyer organizes + pays for it
can send more photos by email/mms
0433087733
(only selling to fund my engine rebuild)
will accept trades/swaps for sr20 parts
https://www.sau.com.au/forums/topic/321360-fs-vic-merc-amg-19-rims/
Curious, how are they redrilled, and still fit the merc?
not sure exectly, idd expect the holes to be mearly drilled out a bit more as 112 and 114 is not that much different, also considering mercs use bolts and other cars use nuts
Do these come out on any particular merc?
not 100% sure its off a 2003 2005 merc of some kind... unsure of which exactly as the rim was only ever issued as a factory "option"
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
