Hi all,
I recently looked at an 1998 R34 GT-T (auto). Build plate says RB25DET, it has turbo engine cover and GT-t sticker under RH taillight. Fasted VIN says RB25DET / HI.2WD / 25GTT produced 9810 so that all matches.
However, there is no triple gauge cluster on top of the centre console?! I know that non-turbo GT's came without these but did any GT-T's?
If not, why would anyone remove the cluster and replace it with the flat cover from a GT?
Cheers
I thought they did have the option for the navigation system on the R34 GT-T instead of the 3-gauge cluster.... this is the pop-up screen that sits in the same spot.
In this situation, the navi unit sits where the climate control is normally, and the climate control gets moved down into a din spot.
Is it possible the flat cover is just the pop-up screen that's not popping up (ie: broken). Should be able to tell if it has a navi unit where the climate control unit is normally...
If it's the proper moulded dash I'd be suspect.
Can you remember what colour the steering fluid reservoir was? Normally the fatal mistake people make is leaving the clear n/a one in, when it should be black on the GT-t :D
Brilliant, I think that's it! Front the top, the centre console has:
1. Air vents
2. Thing that looks like a CD player (controls in Japanese, Compact Disc Digital Audio logo in top right above a four-way controller)
3. Climate control
4. Cassette player
I didn't realise there'd be something popping up, gotta have a closer look.
Can you remember what colour the steering fluid reservoir was? Normally the fatal mistake people make is leaving the clear n/a one in, when it should be black on the GT-t wink.gif
The steering fluid reservoir is next to LH strut tower yeah (turbo side)? It's black, just looked at a photo of a GT engine bay and that one's clear as you said, should be all good.
Thanks guys!
1. Air vents
3. Climate control
4. Cassette player
Thanks guys!
the gtt came out with either the gauge cluster or the pop up screen
my guess is everyone went the gauge cluster because it was a cheaper option !
mine had a screen but i ripped it out coz it was ntsc coded so nothing would work to get it converted to pal would of costed 1000 +
Lucky for us- :ninja:
my guess is everyone went the gauge cluster because it was a BETTER option !
Couple more questions on the same car, didn't want to start a new thread.
The car seems in decent nik but has been garaged for a long time. It drives ok but feels a bit sluggish, when you floor it revs up quick enough but feels a bit 'spongy' and it doesn't really feel like the turbo would kick in properly at all. Could this be the auto slipping or something else? I'll try to run the Auto Transmission Diagnostics when I look at the car next. The 32's I've driven recently go much harder.
There's also a leak under the engine bay with something collecting in the sump guard / undertray - it seems to be on the exhaust / turbo side. Any ideas what this could be? I'll go and have another look over the weekend but thought I'd get some ideas on what to look for exactly. I'll obviously get the car properly checked by a mechanic if I get serious about it.
Cheers!
No leak of anything is good news, discounting the one you take after 10 schooners, if it's dripping as far as he floor I'd get it checked out immediatly , oil , water , brake fluid , trans fluid aaaaaaaaaarrrrrrggggggggggg the bils the bills. :ninja:
Had two different mechanics take a look at the car, all good.
The leak wasn't anything serious and performance is ok for a standard car, turns out I'm just not used to driving bog stock ones :)
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
