Hello Stagea owners.
Just picked up a 02 M35. Reading as much as possible from here before parting with the $$
I just went for the base model RS-4 Silver. Clean cloth black interior, not a mark on the roof. Dead straight panels. 60K mileage. Suspension is quite, tyres brand new. Stereo is simple. Something to get me to the snows this year. Everything works. Probably will get the Engrish conversion done down the track.
Purchased from dealer.
Love the room in it, and the lack of unwanted attention. Down low it is alot more responsive than I expected. More comfortable than the leather V35 seats.
What is Synchro mode however?
Previously owned a V35 Skyline and a S15.
Shannons Insurance $1180. Over 30. Sydney based.
I looked at an S40 T5 Volvo, but this is much better bang for your buck, and such low genuine kms. Smoother car.
:D
https://www.sau.com.au/forums/topic/321432-new-stagea-owner-m35/
:D
Congratulations on your purchase you,ll get a lot of satisfaction out of the car and also have something a little different to the run of the mill motors.
The syncro button is for locking it in 4wd, perhaps you,ll be able to try it out in the snow, good luck with your Stag.
You should have synchro mode and snow mode (both on the same switch).
Synchro = 50 / 50 power distribution except for when you are idle
Snow = is similiar but it reduces your rev's up to 40km/h or something so you don't bog down.
Do a search, there is a lot of information on these two modes in the forums already.
Congratulations on your purchase.
Snow also cuts your boost..
I was told by the dealer I purchased my RS4 from that syncro mode started the car in 2nd gear to limit wheelspin due to high revs/low gear?
That's "Snow" mode he was (or should have been) talking about.
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
