Finally have the 33 calippers fitted to the crossed drilled 32 round things on my M35 but not sure what to do with the rears as there smaller than the ones on my Suzuki .Any advise would be appreciated.Many thanks to Scotty for hes advise with the front install.
Cad
https://www.sau.com.au/forums/topic/321448-m35-brakes/
Happy to help. How did you go with the spacer around the bolt? Did you hack the stone guard right off?
As I dont have a lathe I had them spun up at a cost of $88 & got some 12mm bolts to match the legnth of the 14 mm ones.With some 1.5mm washers to space the callipers out the job was done.The stone guards are a mystery as mine dont need to be altered.Iam using R32gtr crossed drilled fluted discs and the fit the same as the originals;
https://www.sau.com.au/forums/topic/321448-m35-brakes/#findComment-5246984
Cad
All was going well on the R33 calliper transplant onto the M35.The callipers were painted blue & the R32 disc looked a gem but had only one problem,the stock wheels hit the calliper (OOOPS)anyone got a spare set of spacers.
https://www.sau.com.au/forums/topic/321448-m35-brakes/#findComment-5248020
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
