Rs4-s Owners - What Have You Done To Overcome The Boost Solenoid To Run 7+psi Or Is My Understanding Wrong?
so is your post twice as useless as mine ??
and how many people do you see when you look in the mirror??
I know this is off topic, well I'm 50% certain. :banana::ninja:
i have an rs four s
it has a catback exhaust , gutted cat , HDI fmi . standard air box .defi boost gauge
when i fitted the fmi it would run an unstable .8 bar on standard boost controll and was not happy . surgey . hit boost cut a couple of times
i bypassed the stock solenoid and and swapped the waste gate actuator for a r32 one plumbed straight off the compressor housing , rock soild .8 bar car not happy . started pulling timing between 4500 and 6000 rpm
i now have standard waste gate actuator back on and old school avc-r boost controller . .7 bar and car is happy . goes hard . standard coils .standard ecu. what ever plugs came in it . 126000 kays . no hint of a stain above the exhaust 0-100 in 6.2 seconds
im with you mate. considering there are only a hand full RS4S drivers and prob half of those have no idea, its hard to get solid info.
the problem is alot of the info that is being posted is opinion. noone who has posted except lachlanw has experienced something like it. someone earlier suggested to meet up and compare, which is a good idea. its hard to communicate the symptom in text for a start let alone the cure. good luck mate. when you find out the winning combo share it round. always comes in handy for the rest of us.
its late, ill take any flack you think i deserve.
So I'm willing to be labeled a slow learner to get this right :) I didn't install my boost controller and I want to ensure it was done right..
So... Below are 2 pics. One shows the Boost Solenoid and you see the top line is still connected and is plumbed in just above the pod intake. (Is this right??? Reading this re r33 install it doesn't seem right.. http://www.skylinesaustralia.com/forums/In...st-t183405.html
The other photo shows where the boost controller is plumbed in x mark the spot where the line starts then it goes the T piece (its hard to get a photo due to lines running everywhere) and that runs to the wastegate actuator - Im sure thats right.
So should I disconnect and block that hose to the top of the solenoid? Would this be conflicting with the after market boost control?
Cheers again.. Been a nice crash course in bits and pieces re turobs
Edited by BCCairns
seems like its set up a bit wierdly
the line that runs to the solenoid should be plumed into the pressure side of the boost controller or blocked off if the bc has a good source already
the arrow on that small block should point to the wastegate
unplug the old stock solenoid and block off that line, its probably giving you a boost leak <----- Try this first and tell us how you go
:):D :D :):D
It's a new car!!!!!!!! being my first turbo car I didn't know what to expect.. I just thought it took ages to build boost but it looks like I just had a massive boost leak cos that solenoid was still connected on the top hose... Looks like SA user I bought the car from just hooked up the boost controller wrong, man i reckon if he knew he would spew.. With this hose plugged it builds boost in a instant and man it is way more responsive!!!! Look like this could be the reason I couldn't run above 7.5psi I will do some more tests over the weekend... All I have to say is F$u)K yeah, you all rule and thanks for your responses and help... Tom cheers again u rule.....
no worries mate, glad to hear your enjoying it
i had a 32 that ran like crap, put with it for about 6 months and sold it - found out from the ppl i sold it to that the exhaust cam was 1 tooth out and it goes like stink now :) if only i had known
oh well, my stag shits on that thing anyday
I've had a boost leak in my Stagea for the last few weeks. I found that the vacuum line from the back of the engine to the MAP Sensor was barely on the block. Hopefully that was my source of my boost leak. I used the article Bypassing the Stock S2 boost limiter to see what difference it makes to my car. Here's hoping the trip to work is a little better than it has been for a while.
The bottom line from the boost solenoid was the line I blocked when I installed my Turbosmart single stage BC. I have left the top vacuum line connected from Boost solenoid to the intake manifold. It has never bothered me until I noticed the Stagea was really hitting boost like it used to. Current setup is stock turbo, stock ecu, HKS pod filter, stock SMIC, running approx 10psi.
Let me know how you go.... I'm still mucking around with the impact of removing the top line from the boost solenoid. I definitely found the boost is building up quicker and the car is quicker in the lower rev range. Previously it was like the car had long legs and started to boggie later in the rev range.
Let me know how u go.
is there any reason why you couldn't hook the MAP sensor back up? was it damaged or something? you shouldn't have to worry about the factory boost limit unless your running 14psi and higher, which is aftermarket turbo territory. the boost limit wont cause any kind of underperformance or sluggish boost. it is a hard cut out of the engine, as i said in that topic, it feels like you've driven into a solid wall.
i only mention it as i have been told by a tuner that they have seen leaner mixtures once the MAP was disconnected, although this wasn't what i experienced, i could have easily added fuel to compensate. you wont have this option on the stock ecu, do you have anyway to check your mixtures? if not i'd reconnect it to be on the safe side.
Edited by QWK32
It hasn't made much difference in hitting boost haveing disconnected the MAP sensor. It still is a bit sluggish in 2nd gear up in hitiing boost. It kicks in about 5000rpm, whereas it used to be about 3000rpm or thereabouts. I'm guessing it could be clutch related, had a similar problem in my S13. Although for my wallet's sake, I hope the clutch isn't on the way out.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
