As the title states.... I rounded my strut-tower nut! Now i tried taking it off with a 13mm(usually a 14mm) socket and it didnt work! it just slipped!
So then i tried a vice-rip and it just slipped!
I even tried a metric socket and it still slipped...
Anyone here have suggestions?
heres a picture...
Uploaded with ImageShack.us
https://www.sau.com.au/forums/topic/321480-rounded-my-strut-tower-nut/
I tried it, the smaller socket just slipps.... its rounded bad... im gona try a cold chizzle tommorow with a hammer... :) thanks for the quick reply dude. If theres any other way? let me know guys..
Use the easy out's for bolts that have already been posted. Use the right tool for the job, not some hack job that might make things worse or might damage something else. If it's a money issue then buy em, use it and take it back to bunnings and say it wouldn't fit the rounded nut. They will take it back
until you bounce the chisel into the strut tower or mash the thread o fthe bolt with it lol. I know if you're mechanically minded it's not a hard thing using the chisel, but if you're mechanically minded you shouldn't be rounding off a non rusty 14mm bolt either
hehee all good mate :) not saying that the OP was a dumb ass or anything but yeah, some people will read the thread and go and use their new found knowledge and yeah, well you can fill in the rest lol. I can just see some douche bag cuttin ga big hole in his quarter panel with an oxy torch though hahahaaa.
Geraus - Good to see that those bolt extractors worked! They are bloody brilliant things!
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
