Rounded My Strut Tower Nut
@soviet_merlin note how this is a twin scroll manifold and the "fabricator" has tried to make it a merge however I'm not sure he/she/it did very well at school and understand how gas/fluids flow. And why re-invent the wheel? manifolds like these exist, and the merge is great, not to mention the pulses are split all the way to the wastegate's fire ring: -
By soviet_merlin · Posted
Could you elaborate on that? Why? Asking because it's not obvious to me and I always try to learn from posts here. -
Jesus..... You're going to have heaps of boost control issues with that exhaust manifold. -
In the case of repeated flushes, you wouldn't bother sealing it if it's going to be removed again shortly afterward. Any little leak is not going to be a problem. You just seal it up the last time. I'd wait at least several hours, preferably a day, before loading any joint sealed with thread compound. It is an anaerobic sealant, meaning it should go off straight after being locked up between threads. But I find it is still wet long after use. Just give it some time to firm up before pressurising it.
