Melb: 1989 R32 Gtr Tastefully Modified
bump
inspections welcome, comp test welcome etc
will take serious buyers for a drive
also comes with alot of car cleaning stuff in the boot polises, tyre shine, 2x oild changes motul turbolite 4100 and a filter all new
comes with all roadworthy items like steering wheel and cat converter, will all swap back after rwc is done
will provider recipts for work done prior and during my time with this car
alot of extras and - earls oil cooler which i got for 400 is included
ive never raced it, track or drag and suspect no problems whatsoever
if i could raise $20000 without selling this car i would keep it
bump
any honest report from the ncie blokes who came, was the car when i was testdrivig aroind vermount?
drove fairg hard. no problems ar tall.
im also deciding to rip out all aftermarket parts and sell onliine, with the cist benifits amalisists margin is getting closer and closer now
dont let this one goto waste, woudlt be a shame but its only a car.
dont miss out
i have also felt to need to share picrures of my old car
aus spec 31 gx, turbo, R32 gearbox, Pod, front mouts and 600x300 cooler bt exhaustworks
computer mods for electronic fuel pump, new VLT injectrors, paimted bumpers, lowered, rims.
LSD real end dual real sway bars
fronr strut brace
HD clutch
1 peice tail shart
intercooler amd cistoms
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
