Hi all,
I want to sell some of my detailing product.
Here's the list:
1. Menzerna PO85U (used 1%) : $25 (nego)
2. Menzerna APO60 (used 1%) : $25 (nego)
3. Autobalm Bilt Hamber (used 1%) : $45 (nego)
4. Collinite 845 (Used 3%): $25 (nego)
Collinite, menzerna, and autobalm only use for test product only.
Autobalm use for: Auto-balm is a unique product providing protection and gloss to automotive paintwork and car bodywork.
It is the result of thousands of hours of development and testing - a blend of synthesised complex corrosion inhibiting molecules that lock together tightly enabling them to remain functional in ultra-thin, high gloss films. Auto-balm will seal capillary pores in paintwork and provide an anticorrosion barrier to stone-chips and other damaged sites on vehicle paintwork.
Menzerna APO60: Light cleaning ability enhances the gloss of genuine carnauba!
Menzerna Sealing Wax APO 60 is a liquid carnauba wax with a hint of polish to remove light compounding haze and old wax residue. The light polishing agents optimize the gloss by removing build-up and uncovering the brightest, most vibrant paint surface. Menzerna Sealing Wax APO 60 is easy to apply, effortless to clean up, and leaves a lasting layer of high gloss carnauba paint protection.
Menzerna Sealing Wax APO 60 bridges the gap between the warm carnauba shine and the easier-to-apply liquid sealants. It gives the convenience of a liquid wax and the unbeatable shine of carnauba wax. As an added benefit, a light polish enables the formula to achieve its maximum gloss by removing old wax residue and light surface haze – all in one step!
On Menzerna’s scale of cut, Menzerna Sealing Wax APO 60 ranks at a 1. The polishing agents have minimal cut and finish without any micro marring or dullness. Menzerna Sealing Wax APO 60 is the perfect one step cleaner wax to maintain a finish you’ve restored with Menzerna polishes or to clean and protect a vehicle that is only mildly oxidized.
Menzerna PO85U: The perfect one-step polish to enhance new and like new non ceramic clear coated paint finishes.
Menzerna Final Finish PO85U is the original finishing polish made by Menzerna of Germany for use on non ceramic OEM finishes to remove minor swirls and create a high gloss, reflective finish.
Menzerna Final Polish PO85U is a pure polish with no glaze, fillers, or silicones. The water-based formula contains no solvent. It is safe on fresh OEM coatings and new repair coatings. Menzerna Final Finish PO85U will not create new swirls or leave haze, and it creates no dust. It leaves only a high gloss finish on all colors and types of paint, with or without a clear coat.
Use Menzerna Final Finish PO85U on brand new paint finishes or on vehicles in like-new condition. This is an excellent gloss-enhancing finishing polish to deepen the gloss, and remove minor swirls and imperfections prior to wax application. Final Finish can also be used after a stronger polish to remove haze and restore surface gloss.
This is called Final Finish but it’s an ideal first polish for newer vehicles that only have very fine swirls. The abrasives are extremely finely milled to prevent the creation of new swirls. Even on black paint, Menzerna Final Finish will produce an outstanding shine without a trace of micro marring.
Application by hand:
Mist a foam applictor pad with XMT Pad Conditioner to moisten the foam. Apply a .05 cent size amount of Menzerna Final Polish to the applicator.
Work in a back and forth, overlapping motion until the area starts to dry. Wipe off the polish with a damp Microfibre Towel. Work in small sections until the entire vehicle is done.
Application by Machine:
Make sure the surface to be polished is clean and dry. Fresh paint should be fully cured. Apply Final Polish out of direct sunlight.
Use a soft foam polishing pad, like Lake Country’s CCS Black Finishing Pad .
Apply a small amount of compound to the pad. With the polisher turned off, spread the polish over about a 60cm x 60cm area.
Polish at 1200-1500 RPM (4500-5000 OPM on a dual action polisher) working slowly across and then up and down the area. Check your work after several passes to see if the swirls have been removed. If so, reduce the pressure and continue buffing until a high gloss is achieved. If the pad becomes dry, mist it with water and continue buffing.
Collinite 845: Extreme insulation for automotive paint.
Collinite Liquid Insulator Wax was originally developed for power companies to protect against high voltage power failure, electrical fires, and explosions. If it stands up to these conditions, imagine how well it will protect your vehicle’s paint.
Collinite has been making car care products since 1912. This is one of those companies whose products have been kept virtually secret outside of professional detailing and body shops, and car show circles. That’s why there is no flashy packaging and labels on Collinite products. The truth is, it’s not really necessary. Collinite products sell themselves.
Collinite Liquid Insulator Wax, for example, is one of the finest liquid carnauba waxes you can buy. It has the shine and wetness of carnauba but its longevity is more like a paint sealant. You can expect up to 5 months of protection and incredible water-beading, even on non-garaged vehicles.
Liquid Insulator Wax is in a class all its own when it comes to long-term durability, easy application, and paint enhancement. The liquid car wax was created to insulate electrical components, but it has become one of the foremost liquid car waxes on the market by word-of-mouth of Collinite’s very satisfied customers.
Liquid Insulator Wax is used on automobiles, trucks, buses and aircraft where protection is key, but frequent reapplications are not practical. The wax is excellent for fleets. It leaves a high gloss, nearly indestructible clear coating that repels water, pollution, sun, salt spray, bugs, and more.
Liquid Insulator Wax provides tough protection against adverse weather conditions. It makes a great “winter wax” when you want tough paint protection against road salt, snow and ice, without sacrificing shine. Collinite’s headquarters are in New York where harsh winters are the norm. They know a thing or two about durable paint protection.
In the summer, Insulator Wax stands up to the heat and UV rays better than most carnauba waxes. You can even use 845 on boats to guard the hull against salt water oxidation. Now that’s a tough wax!
Liquid Insulator Wax can be applied by hand or using a dual action polisher equipped with a finishing pad. If applying by hand, simply wipe on Liquid Insulator Wax using a poly foam applicator. It takes very little to cover each panel. Buff with a soft Microfibre Towel. You will find the wax easiest to remove if you apply a thin coat and do not let it completely haze over before buffing.
To apply by machine: work at a low speed with no pressure since you are simply applying a product. Use a finessing pad, then buff off with a Microfibre Towel before the products drys.
If you’re looking for durability and gloss in a liquid carnauba wax, you can’t go wrong with Collinite Insulator Wax. It has been a favorite at car shows and in body shops for more than 40 years.
I only give free postage or COD in Melbourne-Balwyn/Boxhill area only.
Outside Melbourne just another $10 for postage, all Australia.
Pics will be uploaded Soon.
Email me if interested. Can't PM.
Thanks
Pictures: uploaded soon
Contact: naldo
Email : [email protected]
https://www.sau.com.au/forums/topic/321531-want-to-sell-detailing-product/
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
