18 x 10 CCW C10 wheels
anodised black
seems to be reasonable brake clearance, more than 6mm at its tightest
offsets difficult to judge whilst suspension is not under load but should be aggressive without sticking out too much by my estimates, fingers crossed for when the slicks are mounted and the car sitting at ride height.
https://www.sau.com.au/forums/topic/321550-complete-custom-wheels/
hey John,
they are 10 inch wide with 6.6 inch backspace - bit rough to convert but maybe +27mm??
welcome to try them on anytime if thats close :cheers:
though with the times your car is getting already i dont know if I should!
hmm that offset might work :D but might have to come and try it out one day
can u weigh the wheel as well ? cheers
mind if i ask how much they are ? and where to get them from ? pm me if u dont want the world to know the price
as i found out at superlap, u can never have enuff tyre on the road
offsets works well up front. will be tucked in at the rear. I reckon I will need a 15mm spacer but will wait and see.
plenty of brake clearance, tried to demonstrate with backlight as I know many of you are interested
thanks Duncan.
only went with this set up after you had done all the hard work trying various wheel/tyre combo's
i would recommend the CCW for anyone who is interested in 18 inch track wheels and is concerned about brake clearance
  • 3 weeks later...
The new wheels and 27/68/18 second hand michelin porsche cup slicks worked well today. As did all the other mods Trent and the boys down at Mercury have been frantically finishing off for today. more on that some other time.
here are some pics of the wheels on at the track. Just over 3 degrees camber, about 15mm lowered. no rubbing.
55.67 on the sprint and 58.12 on the Clubman at QR
    • Yeah since those first 2 replies I actually went and put some 98 in it and tbf it's already doing much better than the 95 (which is weird and makes my inner tinfoil hat wearer think the 95 was a crap batch), getting 8ish around town. Again, wonder if it takes a while to stabilize if the fuel is changed a couple of times. I swear cars used to just either run "well" or "s**t* in my 20s, none of this fuel optimisation business haha
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
