Hey i have been told that my gasket is leaking between my exhaust an turbo. The things i wanna ask is Leaving this too long will it result in future larger problems? How long will it take for a mechanic an How costly will it be? An If There is any stud problem how much is that setting me back also?
Cheers
https://www.sau.com.au/forums/topic/321554-turbo-exhaust-gasket/
i had this on my 33 when i got it needed gasket from turbo to exhaust and gasket from head to exhaust, and studs where sanped in head tho. and to pull every thing off then get studs out put it all back in with all band new studs and new gaskets, it was a all day job morring till dark ,1st time i had eva done that on a skyline too . but i am no mechanic hope that give you a idea of how long it might take
this happened to me on my r34 gtt aswell.. when they were changing my exhaust to a full turbo back he discovered it.
do u have bad fuel economy atm? i got told it wouldnt do the turbo much good if i left it like it for too long and it have abd fuel economy. i had it fixed straight away as the exhaust was already coming off...
Is it the exhaust manifold to turbo or the turbo to downpipe? either one is relatively simple and 800 is definately a rip off! You would only really need a socket set and turbo bolts are not too bad. Drop exhaust pull of intercooler and intake pipes undo heat shields and unbolt turbo, don't think you will even need to remove banjo lines should be able to slide turbo off and on if its that one.
A while ago when I didn't bother doing my own work i had the manifold to turbo gasket fail, i had the problem found and fixed as well as having my cambelt changed for $550
Exhaust manifold to turbo i believe. Yer but you need stands ect or a lift.
All that has to be done is take heat shield off undo the bolts that hold the dump to the turbo. Gasket comes out. Replace with new one and that's it. Would only take about 30mins to an hour for an exhaust shop to do it. I've replaced my dump/front pipe and that only took me about an hour to do myself.
Mmm, How much work is under the car? Just for the gaskets? An did you use some sort of stands for the front/dump pipe?
you can get away without taking dump off. in fact all lines except oil return can be left on turbo. remove heatsheild. undo turbo bolts... lift up. remove stuffed gasket and fit new one. refit nuts and torque up... done
This has happened to me too. But instead of removing the turbo and putting it back on I'll chuck a new turbo on.
Question is about this torque up thing.
I couldn't get a socket onto the nuts, this normal?
and anyone know the correct torque settings?
This is true. It is very easy you have enough room to play with to fit and remove the old gasket.
yeah 17mm spanner usually is the go
FT specs is what i do em... as tight as i can get them and then use those locking tabs.. never have an issue
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
