hi all
Ive had my r33 gtst for about a year now
recently its developed a bit of a problem... when driving an you put the clutch in the revs drop right down to almost 0rpm nearly stalling(it has done on two occasions) and then rises back up to normal.
i am unsure as to what to do and would very much appreciate any advice
it has an FMIC, 3" turboback exhaust, dual stage boost controller (only running 8psi atm), r33 gtr fuel pump, BOV, pod filter, tein coilovers, upgraded coilpacks and other than that is pretty much stock. was serviced a couple of weeks ago and i have recently replaced the fuel filter.
cheers
https://www.sau.com.au/forums/topic/321572-r33-gtst-trouble/
I had that problem too, but it was because I had a bigger turbo, yours is standard so either as mentioned change bov back to standard or relocate air flow meter (afm) to another position and tune.
From what I know, it is occurring because air is going the wrong direction to the air flow meter ie the engine is sucking air and then when the bov releases, some of it is going back the other way or something like that.
I just changed my driving style. ie I used to put my foot down, reach max boost then clutch in and let the car roll.... instead just put ur foot down and then leave it in gear. it wont do it then.
hey mate,
i had a very similar problem to you - it was doing it intermittently so it was a headache to find the problem.. Anyway, the problem was a Pivot "Air Flow" Control gadget, so if you have anything aftermarket that screws around with air/fuel, maybe disconnect those to eliminate them from the equation...
Edited by shaun123
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
