lol confusing....apparently R32 and R33 series 1 is the same. So if R33s turbo and non turbo are the same too..... or are you referring to series 2 that are the same? :P
...or maybe all of them are the same (except R34)....
Edited by TyresBro
i did some looking into this but mainly from the RB25 Neo side of things. i saved this little bit of info that i got from Nissan Fast that might be of some use to you.
R34's, regardless of turbo or non turbo, all go off manufacture date.
05/1998 - 10/1999 use 22680-31U00 alternative p/n: 22680-31U05
10/1999 - on use 22680-31U05
R33's, regardless of turbo or non turbo, all go off manufacture date.
08/1993 - 01/1995 use 22680-02U00
01/1995 - on use 22680 31U00 alternative p/n: 22680-31U05
from that you can take that late model (S2) R33's use the same AFM as R34's. early model (S1) R33's are different and i cant comment on if the R32 RB20 is the same. also turbo and non-turbo models use the same AFM. you need to find out what model ECU you have to know which AFM to track down.
Edited by QWK32
