rb20det is a non interference engine all the other rbs 20de 25 26 30 etc are inteference engines so you should get away with putting a new belt on dialling the timing settings back in nothing too hard if its bent valves you will have to pull it down but i doubt it
  • 1 month later...
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
