  • Replies 76
Posted Images
ummm.... find the menu with the key pad under "phone" , then enter something 4 digit and go "enter" it will pop up a japanese text box with "!" somewhere, leave it on this pop up box (don't press anything) then search for your car using your phone.... select "MY-CAR" and it should pair, and the menu will dissapear...
as for loading iphone contacts into the phone... still working through how to do that! haha
  • 4 weeks later...
ummm... let me find out...
about to go for a drive will be back in a couple hours and note down the steps i took.
Must have been a long drive ? When u get back can u let me know if u remembered the sequences ? Very keen for this. I tryed for ages this morning but have no idea what menu I'm in, they all seem like sat nav menus.
If u can't work it out by the weekend I'm going to take it to a Japanese freind and write down what the menus and buttons say, then post it up.
Hey I paired mine by working it out using the English manuals I posted up.
Obviously I can't remember it exactly as it was a few weeks ago, however, the first button I pressed was 'Settings' (the button that takes you into the menu where the first menu item is the Audio settings (Bass etc) - NOT the menu that takes you into that VICS stuff (which I have no idea what it is)
Once you've pressed 'Settings', then press 'Phone'. It's the first or second selection on the 2nd column / right hand side. You'll know you're in this sub-menu because you can see the English word 'Bluetooth'.
One of the Japanese words on this menu is 'Pair phone'. I can't remember which one exactly, I think it's one under 'Bluetooth', however (again from memory) it's one that takes you to a different screen that has a number entry thing on it. This is where you set the passcode. I just left it as 1234. On this number entry screen one button is 'go back/cancel/delete (number)' and the other is 'OK' (I suppose).
After pressing 'OK' a little dialog box comes up with Jap text and the words 'MY-CAR'. This must say something to the effect of 'Please put your device on discover mode and search for MY-CAR'. I put my phone in discover mode and it connected.
I can make calls with it just fine, but when people call me it hangs up after one ring. I have no idea why it does that and I'd love to fix that one.
Hope the above helps. Corrections welcome.
Edited by Haxorz
I really need to go through those English manuals. I just fumbled around in mine until I was able to delete the previous owners J-pop and classical music off the musicbox. :)
I really like the button that makes a japanese woman speak to me. I'm not sure what she's saying, but its very soothing.
Ideally we'd have a screenshot of each screen with English translations. Not a trivial task of course.
On the plus side each screen has an ID number in the manuals, we can use that to refer to them.
I bought a set of Infiniti manuals from eBay US. Much easier than flipping through print outs in the car (I found them too lengthy to do from memory). I suppose an iPad might be OK.
Note - the US English manuals aren't a 1:1 with the Jap menus, although they are more similar than they are different.
I paired mine the other day and it works a treat. A guy that I'm doing work for on his Rex has a girl that's works for him that spent a couple of years living and working in Japan. She came round and we went through it all.
Unfortunately I didn't have the time to document it all as with me sitting there playing wasn't earning me a living.
But I will give her a heap of pics that she said she would translate for me. I did learn alot!
Yes I also have some crappy music installed on my music box, some old mans rubbish and some japanese bands ... quite funny.
The little circle button on the left makes some japanese lady speak to me. I'll go have a play and see if I can get the phone paired and on the weekend I'll try get some translations if I get time.
Finally got to play with all the options on the car today after being away on holiday. I have now got the iphone's bluetooth Paired, the musicbox deleted and started adding cd's to the HDD (this is v.cool). Has anyone cut the VSS wire and earthed the handbrake cable yet to get video on the move for the other passengers ? I checked out how to do it from the US version but of course our plugs are differen, so if anyone has done it already can they post the pinouts for the two wires and which plug u used ?
Also wondering if anyone has used the AV cables from the iphone through the RCA inputs in the console ? I want to know if the iphone video works on the screen before I buy the cable.
I have done this, plugs are the same. Use the same pinout numbers as show in the US, just ignore the colors. Works a treat :whoops:
yep it does. set the phone to TV out and make sure the cable you buy will spit out video before you buy it. VIM - looks like you found that.
Cheers Chris ... one other question is I got an FM expander the other day and the stupid thing didn't work ... are there some that wont work ? What MHz have u had experience with working ? (I do have the nissan aerial adapters installed)
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
