You can try and fit a valve body from the states and fill it with nissan fluid, It may last a bit longer and can be done with the box in the car, otherwise you will need to replace the clutch packs also, which means a full remove and rebuild. You are looking at around $3500 for that but I warn you, dont get them to high stall the converter or the trans ecu will have issues with locking it up. (as it ramps the voltage to the lockup clutch too slowly)
Kewish Automotive did mine, they have worked on similar boxes before but mine was their first M35 RE5. Shifts instantly and firmly at heavy throttle and softly at light throttle although there is still ecu lag when shifting.
Thanks for the reply. We just tried putting the nissan fluid in the box. No luck there it still slips.
Looks like rebuild time. So leave the stall converter stock is your advice.
I think i will limp it around for a few weeks
I looking into a rebuild about 1 year ago. I was going to use Dominello's in Sydney.
If you are planning on building the motor up and wanting to run a standalone ECU can I suggest you looking into a Manual Valve Body as well. That way you should be able to have complete control of the gearbox without input from the motor ECU.
No keeping it simple just rebuild upgrade the clutch packs. Not planning on rebuilding engine.
I just want to tune it any news on SAS reflash?
Ive got a supra that im forever throwing money at. I dont need another
lol.....wish I had a dollar for every time i've been asked that question.....I can tell you it's getting closer.....but then again so is xmas!
I ring every week....Tom know my voice and my fake ones now....lol.
I can only chase.....personally.....if it doesn't happen VERY F#$KING soon I think I will need to cut and run!!!!!!....I'm sick of having lag till 4,500rpm and a 6,000rpm rev limit because of misfires!
this is the only other real option!!!!!!
http://www.importmonster.com.au/view?url=h...20CON%20V%20Pro
Edited by Jetwreck
It might be i was looking at going down that road soon, but it looks as if it is the transmission first
I got a little bit of mapping stuff if you go down the fcon route and cant find someone to map it for you :) or want someone different to do it.
Anyone dealt with wholesale automatic transmissions in melbourne .
The tranny is a RE5R05A is it compatable with the RE5R05A's out of the other nissans. ie patrol, navara ect
Will a change over unit bolt straight on
Yeh i just spoke to wholesale auto transmissions they said it is a rare transmission and they dont have any rebuilt stock. Lol wish full thinking.
I found a second hand one for $1250 That will get me out of trouble for a few months and give me time to rebuild my one
Transmission let go today anyone know anybody with one.
My mechanic said it will take 3 weeks to rebuild.
Ouch. Mine took a month.
You could get on to the wreckers that bought the white M35, they might sell you a box cheap for 5k :blink:
