That's some weird oil/water heat transfer thing.
Uses oil to get water up to temp quicker.
You can probably remove it all-together RB20 style, I've never looked at it, it's pretty handy on teh daily driver for those cold mornings when you just want the heaters working ASAP haha.
nice and tidy as always, paint looks good
i like the colour matching front lips and one tone cars tho, s13 or c33 is the only one to pull off two tone
thoughts on china spec front facing plenum? should at least make it 500rpms more responsive for full boost, maybe more and i bet its a legal mod in WA :glare:
HAHA if only, instant boost ftw
so just minus 500rpm from current full boost figures
Well as it is now, begins spool at 2000rpm, 10PSI @ 2500rpm, full boost (13.5PSI) at around 2700rpm.
all those numbers are staggered about 200rpm or so down if it's super cold.
So......
I chucked one of these DRIFT steering wheels onto an AutotecnicA boss kit couple of weeks ago too.
Sorry for teh blurry pics, I've tried for the life of me, to get a sharp pic on my phone, but it isn't happening.
When interior is all cleaned properly, I'll take some day time pics.
Having no self canceling indicators and no horn to abuse shit drivers was driving me insane, so the GT-R wheel had to go.
Now I have both again, so I'm happy.
what trubo is that? figure a r33 s1/2 not a31/c33
with FFP =10psi at 2000k should be fun :P
so AutotecnicA boss kit does self cancel? nice
my stocker does well, no clue why everyone upgrade's when they start drifting except for having to look JDM
best looking wheel = nardi and the china deep dish ones
  • 2 months later...
R34 turbo.
Yep, self cancelling FTW, I thought all boss kits did that ...
No clue why anyone uses deep dish at all on Ceffy/Laurel, since you can just adjust the column, and bring the steering wheel closer.
But, it does look pretty sick.
Done some cosmetics, see below.
Gloss black vinyl on B and C pillars on the doors.
Shields back on.
Some stickers - stickers are cool. More stickers are coming.
Interior shot.
Exhaust fixed up.
Well, that sheet of vinyl, was something like 1000x1500 mm, and it was about $50 delivered (eBay).
Pretty easy to fit, the only hard part was the C pillar, I had to dig up the Cefiro badge I ripped off my old door before I scrapped it, used it as a trace to cut that double-circle shape out of the vinyl, then layed it down.
  • 2 months later...
  • 2 months later...
Not much news on this thing these days.
I got some adhesive suede in from some mob in South Korea off eBay.
I messed it up a little at the passenger end, but apart from that it's on all sweet, very easy to bend in and around the shape of the trim piece.
Much nicer than that manky old beige colored shit that was on there before.
Slapped a fibreglass roof wing on this afternoon for MAXIMUM DOWNFORCE!!
That is all.
I'm gonna try and find someone to modify the rear bar for me, bring the rear wheel arch end of it in a little more so it's radial to the wheel the same as the standard bumper.
Edited by Nic_A31
  • 2 months later...
Such a nice Cefiro, one of my favorites. Does your front bar have more room behind it than a s1 bar? I'm having problems fitting my lip as the bumper curves out to clear the cooler (which is mounted as far back as possible) and the lip won't mount onto it nicely
Yes, the S1 bar's mounting points are actually the lower radiator support, the S2 bar drops almost straight down.
I have the same problem, my front bar is slightly bent getting around the intercooler, so the lip doesnt set in contact with the bumper on the corners near the headlights/corner lights, I need to modify my mounts and cut the pipes down to pull the cooler back closer.
Better pic of the interior.
She's off the road at the moment.
Only takes one broken cable tie to f**k your shit up.
Gotta patch that up and going to run it through the engine bay this time rather than through the wheel arch.
This is my new daily monster for the time being
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
    • A seat I find stupidly comfortable to sit in is the one in a friend's Merc Race Car. It even has the huge wings that wrap around your head. Best ever. Only issue is climbing through his scaffolding he put up in the doorway of the car... Ha ha ha. I sat in that seat for a couple of hours doing wiring. Another stupid comfortable seat I find, especially if my back is aching, is my OMP fixed back bucket seat too. I'll just sit on it when I'm exhausted in the garage sometimes to relax!
    • I just got off the phone with Dean from Vosta in Brisbane. They are the ones that do the replica seats and they have a shop full of seats for my to try out. Lovely guy.  I haven't decided whether to go genuine or replicas, I'm leaning towards Genuine at this point but who knows.  Also thinking the STRADIAs are the way to go VS the GIAS since they have a lower hip edge and would be easier to get into. Don't really like the idea of arm rests on the models to the right of this diagram either, maybe they can be removed?
    • From my own first hand experience, keeping power for a fun Street able skyline down at a responsive low 200 wheel KW, is the best. It makes it super drive able through the twisties, you're not just smashing mass wheel spin, or only able to open the throttle for a split second before being at absurd speeds. That said, plenty of people like being morons at more than double the speed limit on public roads and hence are happy with 600whp and seeing 200kmh fly up frequently and fast. Also, at that low 200, a GTR can still do a decent quarter mile, and with a bit of fancy  clutch work (foot, not the parts) can still beat many many cars in a traffic light gp, even in the wet.
