Halfway through the rears...still unfinished as my back was playing up today.
Note, in pics, rear of vehicle is still well and truely clear of the ground......so as usual, don't arc up all like "OI flamin mongrel it needs more LOW!!!" ... I know it does :D
Also dialed in a little bit of camber on the front, the rear cradle has adjustable camber (factory) so I'll adjust that all the way in, which is about 2 degree's at the max.
I forgot all about the Cefiro projector headlights....took a photo on phone (which set the flash off), scared the SHIT out of me when it's eyes just lit up at me....
5 Stud done
Brakes Done
33 GTR Rims Done
Still need to adjust the coilovers, particularly at the front to even up the height, but also a noticeable difference on the Left side.
Motor in, looking all tidy and shit, and now I have it pull it out and make another big mess.
Found a picture of how it looked when I bought it
Motor and gearbox back in now, with R32 GTR gear shifter, which is f**king SHORT indeed.
Comparison - here is the GTST shifter which was a tad longer than the factory manual Cefiro shifters
(LINK) <- selector is in fourth gear in picture.
Here is a 1st->Neutral->Second sequence with GTR shifter. Not the huge amounts of slack in the shift boot.
First
Neutral
Second
At least this fixes the issue with the shift boot stretching, looks alot better now.
Now sorting out the wiring and looking for exhaust solutions.
Almost ready to go back on the road....2 months later :\
Edited by Nic_A31
  • 3 weeks later...
Well....all in and wired up, the ground wire on the relay f**ked up, and all 5 wires going into relay, fused, into one big wire.
Loom f**ked, ECU f**ked, blew switch on ignition barrell.
Halfcut has been ordered, but I'm not a happy chap.
POS is definately going to first c**t in with the cash.
Yeah has been like that since I bought it....think it explains the lack of CD player when I bought it, not too fussed about it now though. I missed out on one on import monster by 30 seconds (someone else bidded on it as well), spewin' bout that.
No news on car, havent touched either in a few days, and actually ENJOYED this weekend.
There should be.
VRDrift is after some parts (as per his other thread) and I'll keep the dash depending on what it's like....was told it had blue LEDs and Mickey Mouse stickers and shit on it....so maybe it WILL be for sale after all.
Halfcut arrived on Friday night.
Dragged it in, quickly inspected it.
Happy and not happy.
It's very different to what I was told, but had some goodies on it and was cheap, so I'll bite my tongue.
Took me 3 hours and 25 minutes to rip to bits on Saturday.
Factory turbo motor, so no BoV.
Manual conversion done properly although the halfcut has been raped for parts, no centre consoles came with it :banana:
Pedal boxes, foot rest, etc all seem to have been bought straight from Nissan in Japan.
I moved the car to a mate's place which is more secure and better suited for yet ANOTHER engine/box swap.
It's been subject to a bit of recon by some shady looking folks, and someone has been trying to steal the plates (although on a plus, consequently my dog seems to have taught itself how and when to jump the fence next to my shed and lay next to the car until I get home)
34 Gearbox is on and ready to go with standard clutch.
25 has been pulled out.
20DET/manual ready to go in tomorrow night, wiring is all sorted and ready to rock and roll.
Hopefully running tomorrow night, and running properly (w/ intercooler + exhaust) by Wednesday/Thursday, and with some luck, the newly acquired LSD in as well
Engine and box are IN and mounted.
Left to do:
Connect driveshaft
Connect ECU to loom
Mount SMIC and drill holes for intercooler piping
Find and fit downpipe
service + fluids
Optional left to do:
Fit LSD
Fit boost gauge
Could very well be running in 24 hours time, finally.
After 7 battery recharges, multiple electrical problems hunted down, alarm completely disarmed (causing ignition engagement issues) and a fuel delivery problem rectified, it STARTS, and RUNS.
Runs very smooth. After no more than 5 seconds into its first run the rpms were stable at 1500rpm and slowly dropped down.
It needs some attention, and a service, badly. Has a oil leak somewhere up the back at the bottom end which I'll have to find and sort out.
But it runs.
It spools up quick, and hard, and likes to blow off intercooler pipes.
Begins spool at mid 3's maybe, hard to say when full boost is on as (and what exactly full boost is with these turbo's) the boost gauge isnt hooked up yet and I wasn't going to run her up to 7k with kids in the street.
Same shit. Different day.
Running.
Battery is losing charge (finally rooted).
Motor is pissing out oil steady-mid rate. (still havent been able to isolate the problem to one point, infact located several leaks which I'm not happy about)
Fuel pissing out in boot. (possibly a rooted O-Ring, or cradle not seating properly)
Have gaskets + seals waiting for me at Nissan.
Sunroof motor has finally broken it's last legs, need to track down a new motor.
Things that I HAVE done:
Bled Brakes + Clutch
Adjusted coilover height, damper and camber on all corners (pics below)
Properly fitted and assembled C33 Laurel dash and some electronics.
Pimp C33 Laurel dash.
(dont mind the mess. Car has again become storage/dumping grounds)
Yeah, the Laurel dash is ripping, and has holes n shit, but it's still much nicer than the Cefiro dash.
One more pic. Kick-ass stance.
  • 4 weeks later...
Got this running properly mid-week.
Mate put on a BBQ on Friday afternoon, in a panic attempt to clean the backyard we threw everything and anything into the Cefiro and parked it up out the front. Being stupidly keen to finally drive it, I only emptied half of that shit (weigh the car down a bit, and having shit in the car makes me behave).
First corner, fuel pump fuse blew.....luckily the corner is on a hill, so, put it into neutral, and just rolled all the way back to my mate's driveway. Fixed the fuse, and THEN off again for a drive.
The turbo on this thing is HARDCORE.
My R32 motor in the other Cefiro would start singing at around 4000-4500 and see full boost by maybe 5500-6000.
THIS little f**ker starts making noise @ 2500rpm seeing 10PSI by 4000rpm.
Also interesting to note that at 4000rpm or later, if cruising at a steady speed, the wastegate actuator will keep the turbo OFF boost (again even past 4000rpm) and only RE-opens when there's a sudden change in throttle. The actuator must feed off rising rate/flow somehow.
Either way, it's great. Virtually no lag, very responsive and once you're up to the speed you want to be at it cuts off, yet ready to spool up instantaneously when you need it.
Also some how does not flutter (at all) when throttle body closes even at 10PSI despite having no blow-off valve at all.....dunno how it does that, possible the ECU feeding a f**kload of fuel? Really don't know, but again, it does it's thing and does it well....it's not killing it's own turbo.
Edited by Nic_A31
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
