On boost is great too.
My 20det on most days would start singing at 2k and make 10psi at 3k, but for everyday driving I found I had to change gears a lot, it bogged down a lot in low revs.
The 25 with r34 turbo starts around 1.9k and 10psi around 2.5k, but even off boost, say 2k through 4k, I can stay in gear without needing to down shift, like going up highway/freeway onramps, stop start traffic, etc. It's much more tail happy too.
It climbs through the revs with a 5kg flywheel about the same as the 20 with a standard flywheel.
I should've just bought this 25 two years ago haha.
Do it man, you won't look back.
I hope all you haters are jelly.
Now, stay tuned for fitment of THIS
On teh way in the next container.
Hopefully less hold ups on this one.
Oh and for the record, 25DET still running flawlessly every day, unlike that god damned RB20.
Best thing I ever did getting rid of that dudd.
  • 4 weeks later...
Was starting to hear a harsh scraping sound at low speeds, gradually became louder.
First thought was low brake pads/rotors, but then I kind of got my head around the idea that maybe, finally, the shithouse bearings on the JJR hubs had finally thrown in the towel, since they last about 10'000km max.
Brakes were getting a bit low anyway, and I'd already bought pads, so I swapped out my rotors for another set, got mine machined, and after about half an hour of looking around my house, shed, room, and in both cars, I found the brake pads I'd picked up ages ago.
Did work at my own house (gravel driveway), and took my sweet ass time.
Was a royal PITA trying to get the pistons in the calipers to retract to fit the new pads over the rotors.
Found the source of that scraping sound too.
The other 7 pads were fine, at around 25%
Finished last corner after about 2 hours.
Ran pads in at local industrial area. They're pretty damn noisy between 15kmp/h and 0, but pedal feels twice as good as it did with standard Sumitomo pads.
JJR wheel bearings are still in tip top condition, 35'000kms and still going strong!
New world record!
Edited by Nic_A31
lol
nick it seems your taking after myself a bit, as you know i did the same to my rears, not too long ago did the same on the front pads!
now the point is to take off my calipers and check them properly at times
whats the deal with these JJR bearings, on paper it says they only last 10,000kms? they better not be pricey to replace
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
