My S2 Stagea has an R34 GTT NEO engine. What's the small bore hose from the metal boost pipe to the valve above the power steering pump for please ?
I've just fitted a FMIC and the new pipe doesn't have a 'T' off it so I've blocked off the small hose temporarily.
makes the steering have less assistance as you are on boost . dont notice it much when driving but you really feel it it you are doing a half launch and trying to turn . mine has been blocked for the same reason as yours for a year now . might hoook it back up to see what its like .
this would do it quite nicely
http://dsrturbo.com/index.php?cPath=45
cheap and could be put in the loiner that goes onto the j pipe
Cheers for that. :D
no worries . when i first said about the different steering feeling about 2 days after i got the car all i got was 10 people waffling about replacing powersteering fluid and ps fluid coolers and shit , none of them had neo motors
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
    • Barrels don't need to be shiny clean. But they are certainly nicer when they are not polluted with years of brake dust, and worse the rotting corpses of the last 17 balance weight sticky pads scattered all around.
    • Yeah, type a special character like ^ or | to initiate the equivalent of the "at"ing for thread links. Although, it might not get any easier to manage. Imagine 30 or 40 threads that kinda match what you want, and the one you want is lost after a long list of useless ones. The magic keyword version I proposed would be a manual effort to set up each case. More of a directed effort from the greybeards to facilitate exposure of useful content. I'm not against the auto complete stuff being considered - maybe por que no los dos? (And where I said "triggered automatically" in my OP, I meant "triggered accidentally". Of course I want it to be automatic!!)
    • Ah yes, fair enough! I was purely thinking about cleaning the spokes and front of the wheel with the mitt. For the barrel the rag on a stick makes more sense. I've tried cleaning the barrels on mine and gave up in frustration. Between brakes being in the way or spokes being in the way and limited space to constantly move the car front and back it was just too annoying. The barrel being as shiny as the rest of the wheel sounds amazing though. At this point I'm not even sure if they have the same surface finish on mine. But I feel inspired now to find out.
