Ive got cusco coilovers in my r33 and desperately need to raise the car about 20mm and was looking at the coilovers to see but it seems it is at its max height but Im not sure, I figure that first compressed spring is for the height and the other on top is for adjusting the spring rate but if I push up the spring rate can I get more room to lift it up? or have I just got the wrong idea about adjusting it.
Anway here are the pics so tell me what you guys think.
Thanks
bit mixed up there so lets clear some stuff up.
The bigger main spring has a set spring rate depending on the diametre of the metal & the number of coils, you cannot adjust the spring rate. If you want to run a different spring rate you have to replace the entire spring.
The smaller spring is called the 'helper spring', its job is to stop the bigger spring bouncing around & rattling when the shock is at full extension & pressure is taken off the main spring. It makes no difference to ride quality as its relatively quite soft & just compresses when the shock is under load.
To get a better idea of how much more adjustment your cusco's have you need to remove a wheel so you can look at the coilover side on as its being blocked by the spring in those pictures. That said you should easily have 20mm of adjustment left.
To adjust them you need to jack the car up to take the load off the coilover, remove the wheel & using a pair of 'C' spanners move the spring perch up the shock shaft. The spring perch is the red bit that the helper & main spring sits on, it may be hard to move due to all the road grime so have wd40 at the ready.
cheers, tim
Thanks
Edited by lidz
it already looks to be adjusted fairly high. doesnt look like theres much adjustment(to raise the vehicle)left..how high is the car now, maybe the springs are due for replacement..
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
    • Hope your all having a mean Xmas! If anyone happens to know any trick to using the insanely complex climate control system, I cannot get it to not be on dual zone no matter how many times I deselect it (will say it's not but both vents blow different temps). Also one side is always hot, one always cold 🤷
    • I'd be looking at the mentioned EFR kit, room to turn it up if decide on e85 (which we know you will) and be super responsive and fun on the street. OR https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/?srsltid=AfmBOorrJa2S76JR5ekXprxBOtU44a1UProbe64YaiVi9zTVp1Lj814w And add whooshy noise for extra fun C5 corvette prices are coming down locally here and a mate has a manual one and is a heap of fun on the street and track.
