Just wondering as to why people generally go for hi flow turbos rather than a brand new turbo? From the prices i have seen the high flow option really isn't all that much cheaper and if you end up going for BB high flow it cost about the same or more than aftermarket garret turbos.
Any information is appreciated as I am looking at one of the 2 options. Was thinking of high flowing but the price seems more than i expected and may as well just go new it seems.
https://www.sau.com.au/forums/topic/321741-high-flow-vses-new-turbo/
The weakness in the stock turbos is their turbines and the bearings. A stock turbo can push 12psi with minimal lag as its optimized for your car. Highflowing the turbo will bring in a new turbine and ballbearing setup with the same boosting characteristics as previous. You will be able to hit boost faster than say, upgrading to a bigger turbo(GT3076 for example). Although a newer turbo may flow more air and create more pressure, your turbo is built for your car and improving your turbo will give you a significant boost.
I'm running a highflowed VL turbo with a GT3071 BB turbine. Comfortably boosts 16psi and I can hit full boost by about 3krpm, positive boost at about 2krpm.
Welcome to the world of upgrading turbos. Where there are so many f**king variables, your brain will explode.
I'm in the process of upgrading my highflowed to something which can push more HP at lower boost. Read my thread for some ideas about turbos(its called Need Clarification or some shit).
Edited by SargeRX8
correct
the turbo itself might not be that much cheaper, but the parts involved in bolting on something aftermarket change that.
another advantage alot of people see is that it looks stock. cops wont bug you, and you get a good upgrade over stock without changing too much.
Highflowed turbo is a brand new turbo engineered to make the most out of your stock housings. So your housings would be the limit factor in terms of max power. The engineering process is inversed, lots of factors to consider, and lot harder to get a perfect result.
With brand new turbos, The housings are engineered refer to CHRA assembly and engine size. So it would have some advantage interms of max power and boost control, How ever it might not fit your stock setup.
So if you are just after abit more power for every day street use, high flow is recommended, else get a brand new turbo.
Ah yea I see people having to upgrade manifolds and going external gate the cost of a new turbo definitely starts to climb quickly when they are taken into consideration.
Since i have the r34 turbo with the bigger rear housing high flowing is probably a good option. Gonna see if i can find someone reliable locally that could do the job for me as i can't go without a car for long periods of time unfortunately.
Thanks for the help
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
