Ok, i recently transplanted a series 2 rb25 into my 32, everything went mostly as expected, used 33 loom, spliced to suit 32 body loom, heres where the problems start.
The car turns over, fuel pump runs like its supposed to, injectors are firing fuel into the cylinders, have 12v power to the white wire on the coils, but i have no spark.
i turned the cas over by hand, and can hear the injectors clicking away, so i figure its not the cas, i have power to the coils, so i figure its not a power supply problem, but i cant work out why i have no spark
please help. im lost.
https://www.sau.com.au/forums/topic/321743-rb25det-into-r32-starting-issues/
so cas is ok if its driving the injectors. and you defo have power to the coils yes? if so have you hooked up all the earthing points correctly?
another thing. wwhere the plug bolts into the ecu make sure the ends of the plug are pushed in all the way as well... have had issues there before.
  • 1 month later...
any luck with this as im now having same problem...
also i can hear injectors clicking away does that also mean that the cylinders are filling up with fuel???
but i also think im getting a very very faint spark cos i can hear it popping but not visible
also can the injectors solenoid go off but still be blocked and not allow fuel therefore not allowing fuel but still making the clicking???
ive just installed injectors and coils and now im have the same problems
ive tried changing ecu too no resolve
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
