Eoi: Rb30/26det And Car
Thinking about selling my RB30/26det, its currently in an R32 gts-t four door and making 465hp at the wheels. I've spent a lot of time and money on this car but I don't get time to use it and I'm not dedicated enough to take it to the track anymore. If I use it on the track I'm spending time and money that would be better spent with my 1.5year old and 1 month old girls. However I absolutely love this car, driving it is like nothing else I've experienced. Engine had a freshen up about a month ago when I pulled it out to put tomei oil pump and head oil drain on.
Would like $20k for the whole lot but I'd like to hear offers too
1989 R32 Gts-t
-RB30 Crank
-Precision Rods
-ARP rod bolts
-ACL race bearings
-ARIAS forged pistons
-Tomei oil pump
-Jun crank collar
-4 layer MLSR steel head gasket (could be wrong about brand cant remember)
-1mm head oil restriction and one blocked off
-std GTR cams
-1inch custom head oil drain
-Head ported by Darren at Lewis Engines
-Modified larger sump with head oil drain and catch can inlets
-T04z turbo
-Trust high mount manifold
-Trust waste gate
-Greddy Y intake
-std GTR plenum, inlet manifold and throttle bodies
-800cc SARD injectors
-Malpasi fuel reg
-GTR engine wiring loom (modified to suit car)
-Power FC D-jetro (maps sensors, GTR plug ecu)
-alloy radiator
-FMIC with 3 inch custom piping
-4 liter custom catch can
-Rear mount battery
-R33 5 speed
-5 puk clutch
-Custom one piece tail shaft
-Kazz 2-way diff
-HSD coil overs
-Shortened front upper control arms
-Adjustable caster rods
-R33 GTR V-Spec front rotors
-Alloy pineapples
-Drift Teks 17x9.5 +15
-Nicely streched rear gaurds
-Hicas lock bar (lines removed)
-Nismo or better fuel pump (cant remember again sorry)
-Nardi stering wheel
-Cobra bucket seats
-Drivers Harness
-Hydrolic handbrake
Probably left a few things out. Also have some spares like 25mm spacers and a few wheels like 16's and 17's although some wont fit over the bigger front brakes. Paints not the best but no rust or damage just not matched properly from where the guards have been done and boot holes fixed. I will try and take new pics if I get around to cleaning it. Only pics I have are from back when I drifted it with the RB20. Haven't drifted the RB30 yet but I might if I find some friends to go to a drift practice with. Car can be registered and has been till early this year however there are some things to be aware of with registering a vehicle with an engine like this.
Thanks people
  • 4 weeks later...
Engine (full engine with all running gear minus power steering pump and air conditioning)
Turbo (on engine with y intake kit and waste gate)
Gearbox (would leave on engine with 5puk clutch)
Tail shaft
Power FC (with map sensors and hand controller)
GTR engine loom with resistor pack for injectors
All sensors, injectors, coilpacks, head oil drain and turbo lines
$14,000
Depending what car it would be going into I also have modified speedo sender and cross member for the RB25 gearbox, inter cooler + piping and radiator and dump pipe Y to waste gate etc.
Trying to reply to all PM's but I can only send one every half hour for some reason so sorry if I miss one or you don't get a reply straight away.
Did a cold compression test all were between the 125psi and 130psi marks. Car is running but not registered.
I've had no serious offers so I'm going to look at parting it out but keeping car so I can sell it cheap later with a RB25det.
First part up for grabs is the turbo kit $3000 for T04z, manifold, waste gate, Y pipe, all lines and S bend (cast turbo to inter cooler pipe).
I thought the compression test was a little low and I just found out why, there is a rubber o-ring missing where the spark plug thread adapter screws on, without it it screws up to far. Also just been told that I should be doing the test hot with all spark plugs out and throttle open which I wasn't doing before so I'll give it another try this weekend.
http://www.skylinesaustralia.com/forums/Rb...Pe-t327866.html
New thread for parting out.
Power FC not sold, got a bit ahead of myself.
Price change to $12,000 ono for complete engine package
Price change to $17,000 ono for full car
Compression test redone, much better, pics attached aprox 150 over all. Engine was about 50-60degrees so not hot but still warm and throttle was held open unlike last time.
Also found video of last event I did, just small mucking around stuff.
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
