Seriously, don't know where you guys are getting ripped off for $30 filters?!
Picked one up for precisely (note how accurate I'm being here) $16.95 and installed it in the dark in the carpark where my other one seemed to have died.
OP this should be in between easy and mind-bogglingly easy, depending on how much stuff you've got in your engine bay cluttering it up.
You're still going to pay someone?
This is depressing.
I remember a while ago, a guy on here had a window smashed, payed like $80 for the glass, and another $50 to fit it? something like that ... literally, 5 mins, in and out, tops...dunno how the f**k people justify spendings like that..
5 minutes to remove the broken glass and fit a new one!??!?
Dude if you can do that I can get you a job as a fitter anytime! In an 8 hour day I'll get 10-15 glasses done, depending on the jobs.
My boss will be stoked if you can punch out 96 jobs a day!
Less than 3 minutes!?
Are we using primers here? You're also assuming the guy has:
Olfa knife and blade
Glass primer
Body primer
Urethane gun
Urethane
You couldn't buy that lot for less than $50, and even if you could, you're assuming he's willing to do a job he may have never attempted
What I'm trying to say dude, is that you should get your boyfriend to change your fuel filter for you :D
He has a Boyfriend or u mean a Friend Boy??? Or he's Gay? Or just too gay to do it himself??
I attempted to do it b4.. not hard my Dad helped me.. 220bux def gettin ripped off unless u like that :)
Glass primer
Body primer
Urethane gun
Urethane
Wrong thread mayhaps?
I attempted to do it b4.. not hard my Dad helped me.. 220bux def gettin ripped off unless u like that :banana:
I am thoroughly convinced that you read through the entire thread to focus on if he has a boyfriend or if he's gay or not.
Fuel filters are piss-easy. Period. Unless they're intanks or something retarded like a late-model commodore with their weird locking clip things. By which you need Norma tools available, from your friendly neighbourhood Snap-On man (Ours is Chris Lovell).
I move for the thread to be closed because it makes WA sound like they've got 4 extra chromosomes.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
