  • 1 month later...
Hi there :ph34r:
Do have the drivers side window motor? If so would you be happy with $80? I'm on the GC so easy enough to pick up if you're ok with that?
Let us know.
:thumbsup:
hi, im after the long part of the dash that goes under the steering wheel colum, its has a fuse box cover on this part im after as well.. only after it if it has no broken mounts and good condtion.. let me know.. thanx
Hi there, was after a pasenger side window. If ya got it still how much posted to Lismore 2480?
Cheers Aaron.
Hey peoples!
I have a Silver 33 Series 2 gtst that I am wrecking have pretty much all parts available. If a part you are after isn't listed, just ask. EVERYTHING MUST GO – Have no where to put all the stuff – so if its not sold by Tuesday (or interest shown) then it will be going to the TIP!!! Don't miss out !!!
Parts are located on Gold Coast, QLD
please call me 0450 269 460 or Jase 0433104519
RB25det - engine – has been hit front on – engine has been pushed back through the firewall – probably needs new cams – bought the engine back in August for $1500 at around 70,000 k's had 160 – 165 compression in all 6 cylinders back then – I haven't drifted the new engine and only been running stock boost. (maybe done 2 skids in it ) been a good engine – so sad! I know when I was looking for a long motor couldn't find anything decent under $1200. . . . but I will let this go for under $1,000 – so make an offer
Standard highflowed turbo – front housing is damaged – but if someone has a blown turbo or something I've been told that you can put the turbos together or something – dunno if anyone is interested – make an offer
Starter motor / alternator / steering rack with ignitation barrel and nismo key
Standard inlet manifold, / Standard throttle body / Standard injectors & rail / Standard fuel pump (maybe on way out? But never gave me any trouble – just something that someone told me – but might be good for someone that needs a fuel pump just for the moment)
Standard coil packs, perfect working order -
Handbrake assembly
Standard ECU – Standard wiring loom –
Air flow meter
Heavy Duty NPC clutch – on way out I thinks
RB25det gearbox / Tail shaft / R33 Diff – shimmed a few years ago
Tein adjustable coilovers – no leakage, like perfect – still have user manuals etc
standard control arms and stuff
Standard strut bars
Rear cradle
HICAS
RB 25 tappet cover
dash surround / centre console / door cards / gear knob / rear interior cards / roof lining / carpet / boot interior & carpet / door sills / climate control / indicator and window washer thingies / hold onto dear life roof holdy things / seats / seat belts / interior lights / Pedals & cables / boot and petrol cap cable / battery in boot holder thingy / Antenae arial thingy (anyone who knows my car knows how clean and tidy the interior was – everything is in MINT condition – even the seats aren't faded)
Rear view mirror / Interior light / series 2 instrument cluster
Silver - 33 rear wing / rear bar / boot / doors / rear windscreen / rear windows / front windows / front window motors / electric mirrors / rear tail lights / side indicators / skyline thing that goes between taillights – centre garnish / petrel cap cover / fuel tank
all reasonable offers considered, as i need to move this gear. Like YESTERDAY – Don't miss out - call me 0450 269 460 or Jase 0433104519
FYI - Brakes & Rear hubs sold - but the actual rear cradle still available and front lower control arms available
  • 4 weeks later...
  • 1 month later...
Hey peoples!
Handbrake assembly
Air flow meter
Standard strut bars
Rear cradle
HICAS
RB 25 tappet cover
hay there i have a series 1 and need fuel rail and injectors if you still have them will they fit my car and how much for them thank you
Genuine limited edition Nismo key + Ignition barrel + door barrels + standard key - $100
if you have still got the above ill take it.
Are any of these goodies you advertised still for sale??
You may not have mentioned some of these, but these are the items I'm particularly keen on....
Interested in 90amp R33 alternator in good nick please
plus passenger door interior trim (perfect or near perfect)
plus boot trim, mat & underfelt
plus electric aerial
plus series 1 drivers side headlight for GTST
Can you advise price & availability please??
I will also send SMS to you
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
