  • Replies 174
aahhh, don't ask dude.
we were having disputes with the trubo supplier and when we came to an agreement, the dude from garrett said that he'll send down a A/R .82 which should be fine, but they actually sent down the A/R .63, and before i knew it, it was already on the car.
i think it should be ok though as the same combo with a A/R .63 made ~260rwkw on an RB30ET at ~20psi.
if i'm not happy, i'll be sending it back to sydney and asking for a .82.
That was a little bit of interesting information. Interesting being the amount of extra boost required for the SOHC head on the 3ltr to make 260rwkw.
you're cool dude.
i actually found out from my friend yesterday that the car i mentioned actually ran 18-19psi when it made that power.
also, another car with that same turbo made 285rwkw on 24psi.
i guess the SOHC makes quite a difference to power as compared to DOHC.
actually, my 2L cossie engine (DOHC) made almost the same power a VL RB30ET (SOHC) would make with the same turbo on the same boost, so i'm happy.
btw, the VL i mentioned which made ~260rwkw with the GT3040 (A/R .63) has run an 11.67@115mph at calder park, and fyi, it's a 5 spd manual.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
