I have had issues where the fuel pump looses its earth contact. Somewhere I read where a member had made up an earth kit for his 35. I have just done it for my C34.
Ok tah.
I'll suggest that to see if it may be a possibility in this case...
Hopefully its nothing to serious, or tedious
  • Replies 44
Posted Images
Nothing new as of yet..
Would it be worth trying to check the ECU Fault Codes for anything?
It couldn't hurt or make anything worse so I'd give it a shot. If something has died or gone wrong it may assist you in pin pointing where to look.
Well, I'm not going to get a chance to do it tonight...
We had our Mechanic friend come around and have a look, and they checked over everything, and fuel seems to be getting to the engine, and the pump is working fine, but it is something else.
Either way, we'll try and see what codes (if any) we can extract from the car...
I read another thread where the AFM had died?
Anyone think this could be the case in mine?
It seems like it's something stupid that died, because Dad got it started after putting fuel in, it was Mum who tried starting it later, then it wouldn't start...
It's up on dad's hoist at the moment, so we can check it all out...
May sound like a stupid question, but I'm not in front of my car, and I don't know them all that well, but where do I locate the AFM?
(yes I am car noob)
Going to go check it out in about an hour...
See if I can get any codes out or anything else...
Edited by 3PointJ
Hi Guys,
Well we checked the AFM, didn't do shit.
Got the code out of the ECU, I cant remember as my memory is shocking, but it was either one of the following
P0120 Throttle Position Sensor/Switch A Circuit Malfunction
P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
Played round with a few other things relating to the code, but still nothing
Anyway, ended up getting it tilt-trayed to the Auto-Electrician, as its sorta becoming beyond our knowledge of what it might be...
f**k.
Try re-seating the plug on the throttle body? Give it a light tap also, in case the contacts on the tps are dirty. Then try resetting the ecu? Failing that I would have to suggest Nissan. :blink:
Scott....how do you have time to be on SAU!!! :)
where are my parts b**ch!!!!
Checked for blown fuses?
Yeah checked that. All appeared to be fine
Yeah gave that a bit of a go.
Bit lost and confused really lol...
See how the Auto-Electrician goes. Hopefully he find something silly that I've missed.
I would clear the codes and try again. see if it spits out the same code again.
It's in the hands of the Auto-Electrician now, so I cant do anything atm.
i have a spare throttle body if you need it!
I'll keep that in mind mate. Appreciate it.
No word from the Auto-Electrician at the moment...
I'm just hoping the issue is not something super f**ked up.
Just to let you guys know, the car has been fixed. It's running, driving all ok...
I haven't been told what the issue was yet, he was just doing some final checkovers, idling was down, so just waiting till its all working to find out.
I'll let you guys know what it is, for everyone else's future reference (in case its an issue no one has experience)
that would be great.....sux being without the car aye!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
