Hey guys
As much as i love the power fc and it's knock feature, i'd prefer a device that would flash a warning light when i'm on throttle and my eyes are pinned on the road. I've decided that the turboxs knock lite would be a good idea, link. I have a couple of questions though
1.Would running off the factory det sensor affect the reading i currently get on my power fc?
2.There are two det sensors on the rb26, which sensor should i use for the turboxs knock lite? i would assume the rear cylinders are more prone to knocking
Cheers
Pat
If you are running a PFC the cat temp or engine check light will already flash if knock exceeds a set level.
If you want something larger than the dash light, just tap into the dash light's power supply from the ECU and run something bigger. We built a custom dash in the nugget with this setup using a 12v LED pilot light.
Good idea, the fc is set at 60 knock before the light comes on, how can i set this value lower/what is a suitable value?
you need datalogit to change the knock level needed for the light to flash. 60 is a fairly good value tho, anything under that isnt serious enough to do damage as a one off thing, of course if its constantly up there then it might be a problem.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
