hey guys.. im on the search for a neat looking surge tank...
now... i dont like the round ones and i dont like the upright ones...
but i do like these ones... because they are square... they come in 2L and 4L.. and are wide enough that two bosch pumps can fit side by side and have neat, parallel hoses to them..
but ive heard not so good things about this stuff. mainly intercooler pipes... and bad quality welds etc... which isnt something you want with a slightly pressurized surge tank..
is anyone using these or has anyone heard anything about them...
or can anyone point me in the direction of one that is similar... i may go with the advan surge tank which mounts under the car but im undecided.
cheers
Linton
https://www.sau.com.au/forums/topic/321944-autobahn88-surge-tanks/
I have no experience with these....but just wanted to note that square might be easy to fit but is a horrible shape to stop fluid splashing around. I guess a surge tank spends most of it's life full, but if not it would aerate the fuel like crazy in a square shape.
Cancel all that if it is actually round or baffled in the middle.
yeh im not sure on that duncan... they call them a swirl pot... but that doesnt mean that they actually "swirl" the fuel being that shape...
i guess i will just go with a round one... its more for asthetics that i wanted square.. but i wont sacrifice fuel system performance over asthetics for something that is in the boot.
cheers.
How much are they?
When I was looking for one I couldn't find anything I liked (same as you, don't like those round ones), so had one custom made for around the same money. They aren't that intricate, mine has internal baffles etc and is a really neat fit which is something that the off the shelf ones didn't seem to be
Sounds nice and affordable. 2L unit will work fine. They dont need to be round. Plenty of surge tanks are made in funky designs. Everything working as it should, they are pretty much constantly full. We have a rectangular shaped one in the race car and it works great! Lol before we put it in we had plenty of fuel surging problems though, that was with a heavily baffled 60L fuel cell. Its suprising just how much fuel sloshes around in a big container when going fast.
  • 3 weeks later...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
