moo_r32: i noticed this the other day too and i think my exact wording was:
"what the.... god damn, I gotta get that fixed...."
sucks doesn't it?... but yeah, mistsubishi electronics etc.... BIG company....
might just take to mine with a bit of sand paper.... lol
Mitsubishi is a BIG company...;)
Hahahahahahah! Thats EXACTLY the same thing I thought when I read the first post!!!
Mitsubishi Electric make eveything from flourescent lights to trains... just ask evo_lee...
  • 6 months later...
Sorry to dread up an old thread...didn't see myself mentioned...hehehe.
Yeah the Mitsubishi Group is very big in Japan, perhaps one of the biggest and oldest group companies in Japan...(Mitsubishi Electric itself brings in 5% of the Japan GDP). If you know your history, Mitsubishi are among the group of companies consider the most prestigious companies in Japan for their role in rebuilding Japan after the war. The Emperor then after the war call upon these companies each involved in different industries to rebuild Japan. You will notice also these companies have their HQ located around the Royal Palace in Tokyo, said to be allocated by the the Emperor...how prestigious can you get! I was very impressed to hear this when I first visited Tokyo HQ. Are you superstitious???...these companies are said to be the primary elements of Japan or protectors of the Japanese economy/industry...if one should fall (fail) = bad omen.
OK the history lesson is over...
So because of their role in rebuilding Japan, they became very diverse in their range of products and services. Course all these products are made by seperate companies or child companies under the Mitsubishi 3 diamond brand name.
I work at the Mitsubishi Electric Transportation Facility in Osaka, working in their Rolling Stock or Railway department, unfortunately not their automotive division but there are alot of equipment we design for MMC and other makers...also other products.
Rail industry wise we are the largest supplier in Japan with 80% market share - JR East and the Shinkansen are all equiped with Mitsubishi equipment...and globally we supply all around. For you local guys, bet you didn't know Sydney trains were powered by Mitsubishi traction engines, inverters and train operating systems did you :P.
Other big Mitsubishi names you would have heard of are Mitsubishi Corp - one of the largest trading house in the world; MHI-Mitsubishi Heavy Industry who make ships, power plants etc and of course Mitsubishi turbos for Trust; Tokyo-Mitsubishi Bank - one of the largest banks in the world; Nikon cameras; Kirin Brewery who also owns Two Dogs but still labelled Australian :P...oh and also MMC who are are now dubbed the problem child of the family and so they deserve to be grilled by other 3diamond companies for giving the family a bad name. They are also so lucky to be bailed out by other family members.
You can check all the Mitsubishi companies from this website.
http://www.mitsubishi.or.jp/e/contents/contents_2.html
So don't be surprised to find the 3 diamonds around...they are not just known because of MMC, the Mitsubishi Group name is much much bigger then MMC who are only one in the family.
this whole Mitsubishi thing has left me and my mates stumped for ages (couple of wees....hahaha)... have mitsubishi things in my car. Thing is my mate used to have an r33 and his didn't have it... So would this be a stock part that nissan had put in when it came out or would it have been added on some where down the line?
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
