so the story goes, my partner started up her 32 a few days ago and it started to pump a little white smoke, she thought nothing of it initally until she backed down the driveway and it started pumping huge clouds of white smoke,
thought i could be a few things so ive pulled the turbo and dump off tonight and the issues are:
Cooler piping from turbo to cooler has trail of oil (more than your usual blowby)
Intake pipe has trail of oil
Exhaust housing and dump are full of oil
And theres alot of condensation in the dump and exhaust housing and a white coating over alot of the oil, is this condensation mixing with the oil or something more sinister ?
theres no milky paste under the oil cap
its been burning quite abit of oil recently
was no sign of any smoke from start up to full throttle when warm before this
given how much smoke it was pumping out taking it to a workshop for a comp test was out of the question,
any info is appreciated, or any tests that dont involve taking it to a shop.
Cheers.
https://www.sau.com.au/forums/topic/321950-rb20det/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
