Hi, I have a few things that I am looking to sell. I have just rebuilt my car (R33 Series 2 1996) and have a lot of items left over. I am open to reasonable offers. Located Sydney
3 1/2 inch cat back exhaust
Jap Muffler (came with car)
Rims and tyres Buddy Club Series 2 19" Bronze - Tyres are Kumo KU 31 with lots of tread 235 at the front and 275 at rear
2 and 3 inch intercooler piping assorted bends and lengths
GTR R33 door trims front and back
Boost controller self adjusting (manual)
Bosch external bracket for fuel pump with rubbers brand new in box from PROFLOW
Apexi Turbo timer in box never used
AUTO GAUGE oil temp gauge brand new in box not used
Universal Fuel regulator with gauge and all fittings instructions INC brand new also
AUTO METER boost gauge with cradle
VENOM 6.5" 3way speakers never used
2 x 12" Calibrae thermo fans
R33 IMPUL ECU chipped computer from Japan
Oil cooler feed with braided hoses and engine block fitting
Short Shifter Kit suit R33/R32 and Slyvia? Never used
Original Coil Pack in good working order
Rotor Break Disks standard in good condition
Thanks guys hope to hear from you - just drop me a line if your interested or have any questions .
Edited by Royal_princess
https://www.sau.com.au/forums/topic/321994-parts-to-suit-r33-for-sale/
How much for the short shifter? Does it have fitting instructions? Pics of the japanese muffler and how much? Is it one of those nice deep but quiet mufflers? I dislike my cannon.
Edit: Also sydney for convenience.
Edited by SargeRX8
short shifter $80. It didnt come with any instructions but I am sure you could pick some up. Can you send email as I am having trouble uploading pic its too big. It is a nice sound, deep not screaming. I am located Homebush area if you want to view. Thanks
Universal Fuel regulator with gauge and all fittings instructions INC brand new also - SOLD
How much for the oil gauge? N how do u hook it up? Thanks...
you can have it for $30 I'm pretty sure there would be instructions in the box but I haven't opened it let me know. Thanks
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
