R32/r33 Cross Drilled Rotors
Hello, I brought the door corner piece awhile ago and trying to gain enough courage to try and replace it. Has anyone on SAU replaced the door corner piece on there car or pulled apart there door/glass and have any tips? Or a detailed door diagram of sorts? Only thing online I've found is https://minkara.carview.co.jp/userid/3313874/car/3031793/6435436/note.aspx
In SAU fashion, thread digressed about 10 times lol. Back to post one, don't hook up the EBC like the OEM bleed setup. Block off the return to the intake pipe and just install the MAC valve between the boost source and actuator. Minor thread derail, go buy a Haltech Elite or Nexus S3 or R3, then convert to DBW. -
I'm not sure I see the reason or benefit behind what was done to the rear upper arms. At least if you break them you can just pull it all and replace with GKTech. For $$, sure. But not brain bleed levels of $$.
