Tell us exactly what you have in your setup so we can tell you if its worth getting new injectors for example if you dont have a z32 even if you do upgrade injectors the afm will still max out and dw about what your gona boost it up to the tuner will take care of that and stop at where it is safe and then tell you if you got room to go more you need to upgrade this and that.
set up is
Highflowed turbo
gredy profec boost controller
split fire coil packs
walbro 450hp fuel pump
ngk iriway spark plugs
3in turbo back exhaust
stock ecu but getting the power fc put in thursday and tuned.
currently set at 12psi but it does somtimes spike and hold 14psi on cold nights
so im guessing by what your saying manni 14psi is the max with that set up i have?
and also what figures roughly would i be expecting with the tune
set up is
Highflowed turbo
What are the specs of the hiflow turbo? Is it a GCG one?
As said above, the stock fuel injectors will max out around 220-230rwkw. Do you want more than that? If so, yes get some larger injectors and a Z32 afm. If you are happy with 220rwkw then you should be fine as is. Most hiflows I know of will make more than 220rwkw. The other way (bit dodgy) is to get a nismo fuel pressure reg to increase the fuel pressure to get more out of the stock injectors, but I wouldnt recommend that because you will still need a z32 afm anyway.
How upset would you be if your tuner says I could only tune on 12psi but the turbo is happy to make more? The answer to that is the answer to your problem. Remember 12psi untuned will be very different to 12psi tuned.
thanks for the info..its made me understand things abit better now...i guess after the tune im going to have to save for some good injectors n a z32 then retune it. and im not sure what high flow it is..all i know is i got it done from hyper gear, gcg doesnt ring a bell but aparently this one is good for around 250kw-270 from memory
Cool, as said above just get the tuner to do what he can with the current fuel system and afm. That will keep you happy for a while then see if you want more later. Only thing is if you do it all at once, you only need to get one tune. but if you dont have the cash, you dont have the cash.
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
