Tell us exactly what you have in your setup so we can tell you if its worth getting new injectors for example if you dont have a z32 even if you do upgrade injectors the afm will still max out and dw about what your gona boost it up to the tuner will take care of that and stop at where it is safe and then tell you if you got room to go more you need to upgrade this and that.
set up is
Highflowed turbo
gredy profec boost controller
split fire coil packs
walbro 450hp fuel pump
ngk iriway spark plugs
3in turbo back exhaust
stock ecu but getting the power fc put in thursday and tuned.
currently set at 12psi but it does somtimes spike and hold 14psi on cold nights
so im guessing by what your saying manni 14psi is the max with that set up i have?
and also what figures roughly would i be expecting with the tune
set up is
Highflowed turbo
What are the specs of the hiflow turbo? Is it a GCG one?
As said above, the stock fuel injectors will max out around 220-230rwkw. Do you want more than that? If so, yes get some larger injectors and a Z32 afm. If you are happy with 220rwkw then you should be fine as is. Most hiflows I know of will make more than 220rwkw. The other way (bit dodgy) is to get a nismo fuel pressure reg to increase the fuel pressure to get more out of the stock injectors, but I wouldnt recommend that because you will still need a z32 afm anyway.
How upset would you be if your tuner says I could only tune on 12psi but the turbo is happy to make more? The answer to that is the answer to your problem. Remember 12psi untuned will be very different to 12psi tuned.
thanks for the info..its made me understand things abit better now...i guess after the tune im going to have to save for some good injectors n a z32 then retune it. and im not sure what high flow it is..all i know is i got it done from hyper gear, gcg doesnt ring a bell but aparently this one is good for around 250kw-270 from memory
Cool, as said above just get the tuner to do what he can with the current fuel system and afm. That will keep you happy for a while then see if you want more later. Only thing is if you do it all at once, you only need to get one tune. but if you dont have the cash, you dont have the cash.
    • Seems to be the case mate , still an OK price for a grey import.
    • I’m interested in the carbon diffuser fins and Toshiba MFD screen replacement if they’re still available.
    • @GTSBoy yeah i know it was not the "great" idea but it is and option...but i think i will stay on no BoV rather then trying to make it work with "half" this and that. But that GReddy FV2 is cool...i like that you can make it like stock if you want (and have/make the custom pipes) For other thanks! it was alot of information. But for the sound...a dont rly "like" both of them...specialy if they are loud...but if i "must" choose i would rather have little whooosh rather than sutututu with no BoV....BUT that is what is i gonna get. So for the all info i gather. In my case:  No BoV is not that bad cuz it is stock...and iam used to put N/clutch right after rpms are around 1000 so it should be ok...just need to avoid "big" drops. But i do not have the engine in the car so i do not really know how "bad" or good it is. But as i had that little test drive it looked ok. The atmo BoV should be worse car would dump to much fuel specialy between the shifts...so without proper tune/ECU i dont want that. BUT with that...car should drive ok with no problems right? (i do like there is less piping wih this solution) 🙂
    • Usually an RB20 won't stay in closed loop idle anyway. The O2 sensor gets too cold, stops swinging.
    • They aren't, but it depends on what interests you about an R32-R34. If it's the front engine I6 turbo that tunes well with a manual transmission an E92 335i 6MT is so incredibly cheap. You can get a super clean one for 20-25k USD tops. Put an LSD in it, tune it, have fun with it. If it's the general idea of AWD + turbo and a manual transmission the 996 Turbo is absolutely much more expensive, it's less practical but it's also basically a complete track-ready car from the factory. At least the Mezger doesn't have heaps of oil control issues. And in the US the 996 Turbo and R33 GTR are roughly the same price these days. 996 maybe a bit more now that the hype has abated for old Skylines here.
