Tell us exactly what you have in your setup so we can tell you if its worth getting new injectors for example if you dont have a z32 even if you do upgrade injectors the afm will still max out and dw about what your gona boost it up to the tuner will take care of that and stop at where it is safe and then tell you if you got room to go more you need to upgrade this and that.
set up is
Highflowed turbo
gredy profec boost controller
split fire coil packs
walbro 450hp fuel pump
ngk iriway spark plugs
3in turbo back exhaust
stock ecu but getting the power fc put in thursday and tuned.
currently set at 12psi but it does somtimes spike and hold 14psi on cold nights
so im guessing by what your saying manni 14psi is the max with that set up i have?
and also what figures roughly would i be expecting with the tune
set up is
Highflowed turbo
What are the specs of the hiflow turbo? Is it a GCG one?
As said above, the stock fuel injectors will max out around 220-230rwkw. Do you want more than that? If so, yes get some larger injectors and a Z32 afm. If you are happy with 220rwkw then you should be fine as is. Most hiflows I know of will make more than 220rwkw. The other way (bit dodgy) is to get a nismo fuel pressure reg to increase the fuel pressure to get more out of the stock injectors, but I wouldnt recommend that because you will still need a z32 afm anyway.
How upset would you be if your tuner says I could only tune on 12psi but the turbo is happy to make more? The answer to that is the answer to your problem. Remember 12psi untuned will be very different to 12psi tuned.
thanks for the info..its made me understand things abit better now...i guess after the tune im going to have to save for some good injectors n a z32 then retune it. and im not sure what high flow it is..all i know is i got it done from hyper gear, gcg doesnt ring a bell but aparently this one is good for around 250kw-270 from memory
Cool, as said above just get the tuner to do what he can with the current fuel system and afm. That will keep you happy for a while then see if you want more later. Only thing is if you do it all at once, you only need to get one tune. but if you dont have the cash, you dont have the cash.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
