Hey Guys
looking for a set of cams type b 260 and a set of cam gears so far the cheapest ive found is $1270 for the lot, can anyone match this?
cheers guys
Edited by Hiroshima Screamer
https://www.sau.com.au/forums/topic/322036-wanted-tomei-poncams-and-cam-gears/
Hey man,
look at: www.perfectrun.com.au or even www.rhdjapan.com
both sell at really cheap prices direct from Japan.
Hope that helps.
i think we have a winner , thanks mate.... have you bought from perfect run before?
Yeah I have purchased from Perfectrun previously - top notch - have got coilpacks and also recently bought HKS cam gears - cheap enough and even postage is reasonable considering it is coming direct from Japan.
I am actually looking at buying Poncams myself in the near future and Perfectrun will be my first stop.
:domokun:
nice.. what was the freight time like?
Freight time was really good, once all payments have been processed the item(s) are sent out straight away, and they usually give a tracking code so you can keep tabs on where it all is - from memory it took no longer than about 10 - 14 days.
Honestly can't wrong, If your willing to wait that little bit extra for delivery direct from Japan it will always work out cheaper than buying locally.
  • 1 month later...
Sorry to revive the thread, but, those prices listed on Perfectrun, are they for a Pair of camshafts or are they for each camshaft? Thinking of buying a pair of camshafts and pair of cam gears/pulleys for the GT-T
The prices listed on Perfectrun are for a pair of Camshafts.
Their prices are slightly higher than usual at the moment due to the crappy Yen to Dollar rate.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
    • Sell it and buy a turbo version will make it a lot faster
