I'm looking to upgrade the fuel system with 2 x bosch pumps and a surge tank.
To keep it legal the fuel system cant be mounted in the boot, plus id like to keep the boot space. With the limited room underneath how have people over come this problem?
PS: I have a 32 GTST.
Edited by Alf
https://www.sau.com.au/forums/topic/322054-undercar-surge-tank-pumps/
Autosport (I think its brads R32 gtr) had this set up.. looks very neat.
Speak to EFI performance. Pierburg external fuel pump. No need for surge tank.
A pump alone wont be enough when the fuel in the tank moves away from the intank pump, thats why a surge tank is needed.
I'm using an 023 intank.
Edited by Alf
Yes I know what a surge tank is for. I understand what you are saying but I have been assured you wont need one with this setup.
Here is a 'quote' from an email from Rick at EFI
"We recommend you look into an extra external pump we use and recommend (pier berg) high volume fuel pumps which are a draw and push pump capable of 350L per minute @ 3bar where the bosch 044 external is only a push pump and with its expensive fittings ect they are rated at only 200L per min @ 5bar."
"We have used these pumps on over 40cars now and are really taking off, they can be used with C16, methanol and are also E85 user friendly where the bosch pumps are not."
Like i said, I reccommend speaking to the EFI guys. They are really helpful and great to deal with.
Any love for the PierBurg?
Edited by RBceffy25
Forgive me if I'm wrong, but a draw/push pump is self priming? It can recover from the air in the fuel lines quicker?
I still can't see how this is supposed to replace a surge tank.
The system on steves gtr was built and designed by myself from steves guidline of everything in one unit under the car.
The current ones I'm using on my GTRs have individual chambers supplying the pumps and are foam filled to settle the fuel a bit more.
I rather use them with dash fittings as opposed to barb tails and clamps.
They work well and are realativly inexpensive.
Ive seen a few jap gtr's with a similar design is it based on a sard item?
It's not based on a sard item.
I jacked my car up, saw a large space near the driveshaft with nothing there, went to autosport and told them what to do and what I wanted. Greg and brad did the rest. I can't weld to save my life.
I wouldVe liked it to be tucked up further but then it wouldn't be as big. Flow was a concern as Brad and Greg figured out the tank had to be over 4L for the pumps I'm using.
The timing worked out great, they fitted all the rest of the fuel setup and the motor aswel. I always recommend them.
they dont say anywhere that the dont require the use of a surge tank and all pumps have to pull push as the fuel doesnt get gravity feed into them.
thats a perfect spot stevo. for a little more detail its the same on the GTSt and the spot is on the drivers side just in front of the back wheel. basically under the rear seat.
Any idea on prices to get one made up (to suit an R32 GTR)?
My mate and I made one the same as the process west unit for his xr6 turbz. Except instead of a billet tank welded down I just folded it up out of 3mm ally and welded it down to a lasercut plate. Turned out much the same and saved the expense. No need for a flashy unit when its tucked under the car and getting dirty constantly.
Edited by r33_racer
Any idea on what one of these surge tanks cost?? Was it a custom one off job or an off the shelf item?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
