It was mentioned to me the other day of a crank shaft repair mob in Brisbane prefer to weld the front of the crank and machine instead of fitting a crank collar. They believed they could better clearances to the pump drive doing it this way
Cost was approx $220-240 which is not too much different from paying someone to supply and fit the crank collar.
What are people thoughts with this method
LOL when the snout of your crank snaps off. It'd be a cold day in hell before I'd weld anywhere near the end of a crankshaft. Considering you can take a crankshaft into Chilton engineering and have the collar supplied and fitted for around $220-$240, why would you even consider something like welding?
Welding a crank can be done, but it is much much more than a simple hit with the mig. If you pre heat the whole crank and use slake lime to cool it etc etc then it will work. This costs a heap more and I doubt anyone is set up to do it properly, but [as Elite says] otherwise you will see it snap at the heat location front where one side is hot as from the weld, and the other side is cold.
I've had a crank welded [it was a one off crank and the splines had been flogged by a cog that when the lock tab washer snapped. You don't pick up on those sort of things until in gets noisy]. It was for a motorbike so a lot smaller easily managed - and is still working today. But the firm [which has since closed down] followed the full process - they knew what they were about and specialised in doing it. The trouble is in our throw away society these days, there are less and less craftsmen and more and more tradies!!!so sadly the art is being lost.
Agreed i had a similar problem & had a bloke in his "Backyard Garage" TIG it up,in sydney.
This bloke is a craftsman,1 look at his "Backyard Garage" convinced me,man wat a setup ,TIG ,Lathe ,Mill,Horizontal borer,grinders unbelievable.
Tridentt , Not May left , the most important thing IS THE HEAT TREATMENT, keeping at A SET temp & then slowly reducing it over set Time,,so many do not UNDERSTAND welding & what the HEAT AFFECTED ZONE is ,it`s the HEAT TREATMEN that return`s all metal`s to former state or close to it,
Now i will WELD MAY CRANK WHERE I HAVE BEEN TOLD TO & DO ALL MOD`S TO BULD A ENGINE THAT WILL LAST & get it HEAT TREATED AFTER ,
I see SOME MANY WELD ALI & then run 30 pis & wonder WHY IT SPILT`S around welded area ,
NORMALIZE SHOULD BE A MUST IF YOU WELD ON MOST METAL`S but people DON`T WANT TO PAY FOR IT ,& DON`T UNDERSTAND WHY IT`S A MUST IN MOST ENGINE COMPONTENT like a CRANK ,
shame we have lost the oldschool way`s & it`s just inthe bin & buy new :bunny:
Cheer`s Chuckie.
Welding affects the metal at a molecular level in more ways that you can imagine. Firstly you are introducing a metal alloy (filler wire) that is of a different grade than the crank material. As it is a different type of metal it behaves differently at different temperatures.
Tig welding focuses way too much heat in one area at a time and mig would not be a pure enough weld, nor would it be hard enough material to bother doing. The metal around the finished weld would potentialy be softer than the crank material, as well as there is the potential for introduced crystalisation of the material.
The only method of welding that is worth considering is submerged arc welding, where the crank is machine welded in a rotating lathe. This then introduces the issues associated with heat warping and material grain disruption. This method is sometimes used to repair crankshafts in industrial engines, and also for building up camshaft lobes prior to re-grinding.
The material the nissan cranks are made out of is extremely good quality. The factory forged cranks combined with the nitriding is the reason the majority of cranks only need a linish before being re-used after 150-200,000K's. This combined of course with multiple heat cycles and work hardening of the crank journels that happens from years and years of running in a low reving R31 skyline, with mineral based oils.
Instead of welding the crank, consider machining back the snout as you would to fit any other colar, and then have an oversize custom colar machined up from 8640 chromoly (gear grade chromoly). Have it interference(shrink fit) to the crank colar with a 0.0011 interference, then grub screw it to the crank. Finally have the new oversize colar machined down to fit your pump perfectly. This way you arent messing with the metalurgy of the crank, AND you have a much harder grade steel driving the oil pump that a built up weld drive would be.
After its all said and done, its a lot of work to do to a crank that is well proven to 9000 rpm with just a JUN extension and a good quality pump (tomei, nitto, etc).
Edited by GTRNUR
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
