Folks
I have for sale a Tomei 2 way LSD.
Comes as a complete assembly including diff housing (pumpkin), making for an easier install.
Unknown kms, as I purchased it second hand.
$650 pick up ono.
Note:
- Its still installed on my car, but will be removed within a couple of weeks.
- It is pretty tight, good for drift and/or circuit
- As with most clutch-type LSDs, it makes a fair bit of banging and clunking noises during low speed cornering (e.g., parking, reversing out of driveways, etc).
- Pick up very much preferred, as the unit is about 55kg in total.
https://www.sau.com.au/forums/topic/322062-fs-tomei-2-way-lsd-to-suit-v35350z/
  • 1 month later...
It has now been removed from the car. $600 ono if anyone is interested.
I feel I should stress that this diff isnt too nice for low speed cornering, parking, etc. However it is great for everything else, particularly sliding.
I'm interested in you LSD and would like to know what reduction ratio it runs compared with the standard diff in the 350GT-8? Cheers, Josh
Folks
$650 pick up ono.
Note:
GT-8 is auto right?
I can't answer your question, but i have a feeling it won't be suitable.
It will probably be a real pain to fit that lsd to your gt-8 i think the bolt pattern on the half shafts will be different.
GT-8 is 3.6 FD open
350gt coupe auto i think is 3.3 FD viscous
350z auto i think is 3.3 FD viscous (i wouldnt mind one of these probably get awesome econonomy cruising at 120k.)
Im probably gunna put a cima 3.6 viscous in my gt-8 looks like they pratically bolt in other than the rear cover which you swap.
Edited by austingtir
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
    • Jousting sticks! Tell 'im he's dreamin!
    • GTR owners are wankers - 2025
