  • Replies 64
jq11 goldcoast - tokyo
jq26 tokyo-cairns
jq967 cairns - goldcoast
These flights worked out the cheapest way to go, few hr stopover in cairns, but meh, will be good to adapt to the humidity again! got Big Day out a few days later. So i thought might be good to just suck it up.
  On 19/12/2010 at 3:19 AM, Rbware said:
You will see the sau-sa/vic group there they will all have there Red hoody's on come up and say hi.
I am heading over with the SA Section of this group. The group is wearing hoodies that look like
  On 13/01/2011 at 12:42 AM, Mushroom said:
well i arrived ok and what an awesome place, just come back from the fish markets :)
bring on autosalon :)
Tsukiji fish markets?? If so then yes it is awesome, how good are the free samples. :D
  On 14/01/2011 at 11:29 PM, Uber Motorsport said:
actually i wasen't charging him
i was going to give them to him,
on another note guys
for anyone who is there check out the Dry carbon doors on the Top secret stand weighing 4.2 kg
No problems, nice thought..
Just know where he lives in relation to Tokyo and trying to find another gaijin at Auto Salon, well you know for yourself, the place is full of them.
And yeah the carbon on the Top Secret 35 is very nice. Got to go through their car a few weeks ago.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
