yeah its kinda a major no no . like big fines . really big . like 5 figures big .
there will be a nipple on the pipe somwehere that has what looks like a tire valve cap on it . or one of the lines off or unbolt them
https://www.sau.com.au/forums/topic/322086-de-gasing-ac/#findComment-5253283
legal way: drive to local aircon place. ask them to degas aircon. hand over keys. come back after however long they tell you.
the job itself should only take about 5 mins, but depends on how busy you are. as to how much they charge i wouldn't know, but it shouldn't be too much.
https://www.sau.com.au/forums/topic/322086-de-gasing-ac/#findComment-5253341
shouldnt cost much, they will suck it out with a recovery pump into a bottle of waste R134a Refrigerant.... if your planning on removing air con lines and such you will need a new reciever drier when you put it all back together
https://www.sau.com.au/forums/topic/322086-de-gasing-ac/#findComment-5254052
ahhh shit lol.... it been to long since ive been taught air con systems
I googled it for you cause I wanted to remember what it does as well...
RECEIVER-DRIER
The receiver-drier is used on the high side of systems that use a thermal expansion valve. This type of metering valve requires liquid refrigerant. To ensure that the valve gets liquid refrigerant, a receiver is used. The primary function of the receiver-drier is to separate gas and liquid. The secondary purpose is to remove moisture and filter out dirt.
Air Con Information
So basically its for the secondary reason that you must replace it because it will absorb alot of moisture from atmosphere when it is disconnected from the system.
Edited by 89CAL
https://www.sau.com.au/forums/topic/322086-de-gasing-ac/#findComment-5255873
