another good way to shoot flames is to snap your exhaust cam but have it still holding together enough that it all still turns but the timing is ridiculously retarded and then you can just sit there and go on and off the throttle and it will shoot flames.
here is a video of it
flames are part and parcel of a high performance engine... on a race track... with a straight through exhaust..
there is no need for such things on the street... other than trying to make your car cool by purposely adding things to make your car look like the cars that make the same things as a by-product of them doing their job.
and a "high performance" rb20 will happily pop flames... evidently yours is not quite high performance enough..
having flames come out the rear is only good for people that ride your backside and lighting their front bar on fire lol as for not being able to get the black stuff off your car just use some polish and a bit of elbow grease
Ahh my weekly ritual.
Edited by PM-R33
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
