Rx7 injectors arent very good for use in cylinder motors, the spray pattern is not very nice and most of the time you'll struggle to get a decent idle. They are a decent size for cheap but your better off spending that little bit more for some proper injectors.
I bought a set for my motor originally back in the day, and we had to go through 8 or 9 injectors before we found 4 that flowed the same and werent f**ked
Edited by DR JOSH
https://www.sau.com.au/forums/topic/322110-rx7-injectors/#findComment-5258961
nice way to bad his thread mate.
https://www.sau.com.au/forums/topic/322110-rx7-injectors/#findComment-5259152
rx7 injecters are good, compared to high flows atleast..
since runnin them my cars idle is allot smoother goes through less petrol and starts easier and actually drives better when cold, car still pumped out an easy 400hp ...
but yea spray pattern not so good, still better than high flows
https://www.sau.com.au/forums/topic/322110-rx7-injectors/#findComment-5276918
yep!
375cc hose tail @ 3 bar.
RX7 are O'ring and 550cc @ 3 bar.
I'm using 380cc hose tail @ 3 bar in my L28et rebuild and 780cc Rochester Delphi (14mm O'ring) in the FJ20et, or maybe 770cc Siemens Deka. Doesn't matter as I have both plus 570cc if I choose to use premium 98/100 octane petrol.
Cheers, D
https://www.sau.com.au/forums/topic/322110-rx7-injectors/#findComment-5298442
ok well iv got a set of low imp 450cc mitsubishi 4g63t injectors that came out of a good running car i might fit those for now unless you want to sell me your rx7 ones for 100 dennis? i know im low balling you but there is a set on my mates mitsi forum flowed and tested for that money.
they have really come back in the money
https://www.sau.com.au/forums/topic/322110-rx7-injectors/#findComment-5299159
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
