Gday all
I have just lowered the Stag using BC coilovers which I am very happy with, I was worried that they where going to be way to hard for the Tassie Rd's but they are very comfortable.
My ride hight is 340 front and 350 rear I am concerned that i am running with to much camber so I am wondering what people are doing, whether using adjustable camber arms and if so what brand or if you are just leaving it as is.
cheers any info would be good
https://www.sau.com.au/forums/topic/322124-to-much-camber/
The reason you want to correct it is with lots of negative camber (youll have around -2.5 deg at that height) you chew out the inside of your tyres very quick!
And you will max out the stock ecentric adjuster bolts thus needing arms.
https://www.sau.com.au/forums/topic/322124-to-much-camber/#findComment-5254018
not 100% correct. you can run stacks of camber and have your tyres last for a very long time
it is toe settings that destroy tyres :P
r33/r34/s14/s15 rear arms are the same
https://www.sau.com.au/forums/topic/322124-to-much-camber/#findComment-5254404
auto...
s14 camer arms
s14 toe arms
manual with hicas
r33 hicas lock bar
s14 camer arms
.... seach on ebay.. or look at isc-coilovers.com.au ryan on here will sort you out...
to install just take ur stock ones out.. lock them to what the stock settings are by eye... then get it allined.
https://www.sau.com.au/forums/topic/322124-to-much-camber/#findComment-5254503
I hear ya...
Slam it, add camber arms, wear tyre's out... scratch head...
then adjust toe and all good....
Killed some GOOD 18's in 10,000km's by doing that :P
https://www.sau.com.au/forums/topic/322124-to-much-camber/#findComment-5254570
Im installing Camber Arms on Thursday...
I currently have 3.0 degree's in the rear :P .
Im going to try my luck with Only camber arms and max the Ecentic Bolts.
I'll post up my results Thursday.
Either way, I will be pulling them back to 0.5 degree's or till the tyre wants to touch the gards, which ever of the two occur :P .
Toe arms may be on the menu at this rate...
https://www.sau.com.au/forums/topic/322124-to-much-camber/#findComment-5254629
No point, just get toe arms put them in and get an alignment do it once do it right.
https://www.sau.com.au/forums/topic/322124-to-much-camber/#findComment-5254790
Do it once, do it right. Indeed :)
I got bored this afternoon and decided to install the camber arms.
Only by eye, that I can tell, the rears still stand on and angle.. so abit more to go.
I was shocked by the amount of Toe it currently has. I drove it down the drive way to turn it around... tyres didnt appreciate it :ermm:
So Im off to get some Toe Arms in the morning.
https://www.sau.com.au/forums/topic/322124-to-much-camber/#findComment-5256879
