my car is not running properly i think.. i only have minimal mods but it does not have much more than stock power wat could be wrong. it has a front mount, boost t 11pound , cat back 3inch zorst, heavy duty clutch. its only got 140atw.. could it be because of stock dump pipe???
https://www.sau.com.au/forums/topic/322133-car-not-performing/
do you have any type of piggy back computer or aftermarket computer. if not then you cant expect much. your afr's will be all over the place and (most probably rich) . once you get something like a SAFC2 (fuel only) or power fc (ignition and fuel)your power will go up to realistic levels.
Blaming the ecu is an easy thing to do. Could also be the dyno reading low. Post up a dyno sheet.
I wouldnt say anything is wrong.
Do the basics first, ie servicing(plugs/oil/timing/ecu reset, etc).
Mine pulled 175rwkw with only a catback and a pod and 12.5degrees and was only running 9psi.
thanks guys i changed the dump pipe and im installing an eboost with a fcd within the next 3 weeks just need money for the tune.
even with the dump pipe changed i have noticed a big increase in spool and top end pull, so looking forward to the e boost :kiss:
the cat is a xforce one so i think its decent
Edited by havoc_r33gtst
Please please do not install the FCD. Do your car a favour and at least try and get a Apexi SAFC II
I've got an SAFC II if you want one - sitting on bedroom shelf. I used it when I had similar mods to you - works well and gives other info like voltage levels, knock, etc.
Id be going a compression and leakdown test before anything else.
180rwkw is a base figure for thos mods.
Personally for mild mods like that i wouldnt bother with an aftermarket ecu. Your not really going to get much top end power. Fuel economy would be better though.
Edited by Pattygtst
ive got 3inch turboback, profecb @ 11.5psi, fuelpump, fmic, pod, hiflowed injectors(unnecessary @ this stage), afc neo, made 197rwkw @ chasers then detuned to 193rwkw
tho it was just an afc it felt tad better to drive after tune
140 looks low friends auto made 150's with only pod and turboback @ stockboost
140 is way low..
mine made 186kw with dirty old apexi pod turboback and 11psi coutesy of a tap from bunnings...think it has a better fuel pump too..
Edited by Arthur T3
whats your compression like....
you need to find the problem not buy more shit...you should be getting around 180kw...something is wrong..fix it then buy more shit...
+1
you have a problem some where and an Eboost will not fix the problem.
is there a way to raise compression if its down or is the car f***ed . could this be fixed if the mechanic i am going to checks it out ???? i bought it stock and then i got a boost tee installed the mech installed it and dynoed it he charged me 550 and it didnt seem to go much better even though boost was increased by 4 pound . since then i have changed mechanics but havent dyno tuned it ... should i ???
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
