hey guys for sale -
Item:
Black 1985 Nissan 200ZR 4 seater Manual
218XXX ks on the car - engine is a silvertop RB20DET from a r32 skyline and is said to only have about 150000 on it
mods -
Skyline r32 silvertop conversion
standard redtop top mount intercooler
MSD v6 commodore coil conversion
HKS blow off valve and intercooler piping
Full 3 inch exhaust from the turbo back with hi-flow metal cat
boost gauge and turbo timer
GFB boost controller
front coilovers with wheel spacers
if sold for the right price, a brand new front mount intercooler will be included
Pioneer 7950UB head unit with ipod control and usb input
Fusion powerplant 6x9s in rear tray
Comes with 4 Skyline r33 rims and tires, 2 need tires replaced, also comes with two z32 300zx wheels and tires
Immobiliser and alarm
Im sure theres more that i cant think of at the moment
Registered till 23 June.
Please feel free to come have a look. Contact me on 0430365458.
Price: Asking $3000 ono
Thanks guys
Pictures:
  • 1 month later...
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
