I have a Pioneer iPod adaptor to suit multiple Pioneer iPod ready headunits. This hides away behind the head unit, with a cord to plug in the iPod. This comes with all cables and I have the User Manual on PDF on the computer as well.
Easy to install, has power, ground, plug to iPod and then plug to back of headunit.
This can be used for the following models:
For use with Pioneer “iPod® Adapter Ready” Headunits and AV Receivers. Compatible models include:
* Full Touch-Panel Control models: AVH-P7850DVD, AVH-P6850DVD, AVH-P5750DVD
* Full Rotary Commander Control models: DEH-P9850BT, DEH-P8850MP, DEH-P7850MP, DEH-P6850MP
The following models can control the CD-IB100II through "External Unit Control", with some limitations in operation and display. Please consult the owners manual for more details.
* AVH-P7650DVD, AVH-P7550DVD, AVH-P6650DVD, DVH-P5850MP
* DEH-P5850MP, DEH-P4850MP, DEH-P9650MP, DEH-P8650MP, DEH-P7750MP, DEH-P6750MP, DEH-P4750MP, DEH-P3750MP, FH-P5000MP, FH-P4200MP
Price: $100 ono + postage for those unable to pickup.
Condition: Worked last time I had it with my Pioneer headunit, but the headunit itself jammed up on CD function and so I bought a new headunit that wasn't Pioneer.
Contact: [email protected] or 0401 443 980 begin_of_the_skype_highlighting              0401 443 980      end_of_the_skype_highlighting
Pictures:
More information:
http://www.pioneer.com.au/Products/Car%20E...IB100%20II.aspx
http://www.modyourcar.com.au/pioneer-ipod-...cdib100ii-p4913
https://www.sau.com.au/forums/topic/322173-pioneer-ipod-adaptor/
As I have only just started advertising and am in no rush I will do for $100 delivered by regular post or $110 by delivered registered post.
Let me know if you are interested.
Yvonne
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
